Question about Admiral Refrigerators
How do you shut off the water to the refrigerator? Water suddenly began running out of both the automatic ice cube dispenser water port as well as the water dispenser in the door. Neither would stop flowing. We would like to find the shuttoff on the water system within the unit so that we do not have to shut the water off at the pipe. Is there a shut off in the refrigerator's water system and if so, where?
  • 10,865 Answers
Find the valve where the 1/4 inch feeder tube taps into a larger cold water line. Usually in the basement, sometimes under the sink. J.
Posted on Jul 07, 2010
  • Admiral Master
  • 8,220 Answers
Back of the fridge follow the water line out from their to the shut off in the wall.
Ge ziss48drss ice spitting out
Sounds like the buttons are sticking or the board has malfunctioned and sent power to all of the relays. I would look to replace the board or just find a way to disconnect it.
Sep 06, 2012 | GE Monogram ZISS480DRSS Stainless Steel
Tip
How to fix a leak inside a refrigerator
Turn off the refrigerator. Remove the rear panel and floor cover from the freezer. You will see a lot of ice covering everything. Remove/thaw this ice.
In the back of the freezer, under the coils is a drain. When the defroster runs and melts the ice on the coils, the water is supposed to run down the drain to a pan where it is evaporated by a fan under the refrigerator. Often, this drain freezes shut. Then, the water has no place to go but though the vent into the refrigerator.
Melt the ice in this drain with a hair dryer or small quantities of hot water. You will know the drain is clear when the water level suddenly drops. Finish drying everything in the freezer and replace the panels.
Now, you will no longer have water dripping inside your refrigerator.
on Feb 06, 2010 | Refrigerators
Water is not working
Che k if the weather line has not been shut. Also replace the water filter
Jul 25, 2012 | Whirlpool Refrigerators
The refrigerator water dispenser started running without pushing the device. It won't stop unless the freezer door is open. We were just sitting in the family room and all of a sudden the dispenser...
Pull the fridge out and look behind it. You're looking for the water line that could possibly have valve shutoff. If not, follow the line back to the source. Could be tapped under the sink, could go anywhere. You are attempting to shut off water to the fridge without shutting water off to entire home. Worst case scenario is if you can't locate the fridge shutoff and you can't get it fixed today and you don't want to leave the freezer door open, locate the main water shutoff for the house and shut it off over night. Hope this helps.
Jan 26, 2011 | GE Monogram Side by Side Refrigerator
The water refill tube on my icemaker freezes constantly all of a sudden. The water pressure seems low also, I used a self-tapping valve could this be a culprit? I have a Frigidaire model # 26BRSDB1. Thanks...
Most times the reason for the freezing fill tube is a leaking water control valve for the ice maker side. Unplug the electrical plug to that side on rear of refrigerator. If water continues to flow to ice maker the valve is leaking or damaged to the point that closing is not enough. If suddenly began I would not be concerned about a tap valve. Thanks, Sea Breeze
Mar 24, 2010 | Frigidaire FRS26R4A Side by Side...
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Water/Ice Dispensor Malfunction
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure the refrigerator has the blower problem for which the problem arrises ....... please visit your service authority...........have a nice day:-)
Mar 02, 2009 | LG LRSC26920TT Side by Side Refrigerator
Water in door will not shut off.
most like the dispenser micro switch is stuck open.. it could also be the inlet water valve.. but I could check the switch first...let me know
Sep 29, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
232 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
