Question about Goodman Heating & Cooling
On a goodman package unit the led on the board says compressor output delay. check compressor anti-cycle.
4 Suggested Answers
  • 5 Answers
SOURCE: Newly installed Goodman GPG13 gas/electric
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Posted on Sep 22, 2008
  • 147 Answers
SOURCE: Compressor will not start.
If the unit is low on freon it will short cycle but a compressor internal overload will cause it to. Lets hope its the freon. Has it been frezzing up lately. Low freon is the cause most of the time. Make sure your filters are clean and both fans are running. Hi head can cause this to. (fans not running) How old is this unit. Maybe the coils need to be cleaned. Sound like this unit may need a check up and a good cleaning.
Posted on Nov 02, 2008
  • 116 Answers
SOURCE: My Goodman air handler RELAY, ELECTRONIC BLOWER
when this happens turn off power and feel motor if hot capicitor i dont think this board cost much but if it does you can get a fan sequenseing stack switch to repace the board with
Posted on May 12, 2009
Why does the compressor on my goodman package unit turn on and off before completing a cycle while the condenser fan runs?
Two most common issues are a bad run capacitor or the compressor is over amping due to bad bearings.
Sep 02, 2014 | Goodman Heating & Cooling
Why does the compressor on my goodman package unit turn on and off before completing a cycle?
There is several possible causes. The most probable cause is wrong charge. Many units have a low suction safety on the low pressure side of the compressor. There is often a high pressure swithch to guard against over pressure also on the high pressure side. If your unit has the condensing fan stop in mid cycle, the compressor has inherent motor contacts inside the compressor to help guard the compressor from overheating. I just recently had to replace several customers main contactor because the contactor contacts were severly burned and sometimes could pass current and sometimes could not. I also had a few customers whose condensing unit was so dirty that the compressor was overheating causing the inherent motor contacts to open. Hope this gives you some ideas to look.
Will not come on but emergence heat works
Check contactor that operates compressor and condenser fan. Does it try to come on when you first turn it on, or just sits there? If it tries to come on, it could be the capacitor.
Jan 25, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Goodman ck36 1b a/c. Capacitor replaced 2 years ago. Unit is 13 years old and thermostat is Honeywell, also 13 years old. This summer there seems to be a 3-5 min delay (from when thermostat registers call)...
If you have a AC unit with electric or gas its doing what its supposed to do, let the pressures in the system equilize before starting again, If you have a heat pump its doing it there as well you just have not noticed. Anti cycling is a good thing, 4 to 5 minutes is normal.
Jul 05, 2011 | Goodman Heating & Cooling
We have a Goodman CKL 3.5 ton 10 seer AC unit. it is labeled Amana Distinction. it is installed in 2006. CKL 42-1L. The problem is that when the wall thermo control kicks on, the fan blows 3 minute of...
Yes there is a way. First You need to see if the outdoor unit has a time delay on it.It would be connected to the contactor and the low voltage wires. If there is not one then there is a problem with your thermostat. If you have the thermostat manual, check to see if there is way to change from the 3 minutes to none. I hope this helps you.
Jun 05, 2011 | Goodman CKL24AR24 Air Conditioner
Goodman model pgb030075-1 unit has led flashing on circuit board (1 flash) replaced open rollout switch unit heated for one cycle,won't refire makes three attempts then locks out
maybe the exhaust fan is not getting power, here is a website that should help, Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Nov 12, 2010 | Goodman Heating & Cooling
My heat pump package unit compressor draws high amps and keeps going up until it blows the 40 amp fuse on heat only. and on cooling only works for a minute or two and shuts off and starts again but draws...
This could be many things, but check the following:
1. The reversing valve - make sure it works and is in the correct position for the selected operation (heating or cooling)
2. Turn off the power to the system. Megger the compressor - this takes special instrumentation, but if you don't have it, set an ohm meter to Ohms x 10,000 and check each lead to ground as well as phase to phase. Look for shorts or open windings. You will need to disconnect the compressor wiring
3. If the unit has auxiliary heat, make sure the elements or the controls for them aren't stuck on - this could be a control board problem.
4. Check the outdoor unit defrost cycle for stuck heating elements or a faulty control board/stat.
5. I'm not sure if this unit has hot gas defrost, but if it does, that should also be checked.
6. Check the compressor contactor and make sure the contacts are transferring the power to the compressor. Amp check each leg to determine this.
Dec 22, 2009 | Goodman CLJ30AR32 Air Conditioner
I have a pos goodman unit GMP075-3, my problem is the indicator led blinks 4 times regarding an open limit switch in the system. I'm trying to turn the A/C unit on, the control board is brand new &...
check for manual reset switches around burner area. These switches will have two wires going to them and a little button in the middle of the switch. You might hear a little click if they were tripped.
Aug 31, 2009 | Goodman Heating & Cooling
My Goodman air handler RELAY, ELECTRONIC BLOWER TIME DELAY makes a clicking noise 4 or 5 five cycles (about 10+ Sec delay ) before the squirrel cage fan will come/stay on. I have reset the unit by switch...
May 12, 2009 | Heating & Cooling
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
318 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
