Question about Abacus Concepts TV Slideshow Studio for PC
Error message "Error (Class not registered) the application will
When trying to open the program all I get is error message
"Error (Class not registered) the application will close!"
I previously had this program on my computer running Windows XP untill it recently crashed. I Have reinstalled Windows XP Professional Edition.
I have 2 sams4s 2000B registers. The second register is giving me an error message when I try to z out a shift. It says not allowed with open orders #28. I have checked both registers nothing on hold
Have you made any changes to your computer prior to the issue?
Here's the simplest method:
Run SFC scan. System File Checker (sfc) scan will make Windows replace corrupt or missing system files on your computer.
Steps to perform sfc scan:
a. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
b. Click Continue or supply Administrator credentials if prompted.
c. In the Command Prompt window type the following, and press
Enter:
sfc /scannow
Refer these articles for more information:
https://answers.microsoft.com/en-us/windows/forum/windows_7-performance/how-to-fix-error-message-class-not-registered-in/1a2e8a40-6dec-42e1-bb85-70a719e9fbbb
https://www.techwhoop.com/class-not-registered/
Oct 19, 2017 | Retail Supplies
Windows xp: class not registered
Normally ,windows give this error when some .dll file is missing...
I think better solution is to repair you windows XP using installation disk.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com
Aug 28, 2012 | Microsoft Windows XP Professional x64...
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
VB6 error 432 File or Class name not found during automation
The GetObject function requires either a valid file name with a path specification, or the name of a class that is registered with the system. This error has the following cause and solution:
The name specified for file name or class in a call to the GetObject function could not be found.
Check the names and try again. Make sure the name used for the class parameter matches that registered with the system.
Mar 08, 2010 | Computers & Internet
I was trying to install a program for my college
Your program did not install properly. Based on the error message "Resize32.ocx" or something it needs to run did not install properly. Uninstall through control panel-add/remove programs and reinstall.
Jan 14, 2010 | Sony VAIO PCG-K33 Notebook
"there is no application registered for this event" error message
I need to reinstall on my new computer my canonscan lid 25 and misplace the cd
Oct 04, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
I get an error message when i try to download java
IF YOUR DOWNLOADING FROM INTERNET THERE WILL BE SOME ERROR IN THE APPLICATION (OR )YOUR FILE ERROR WILL BE EXISTING .TRY TO GET NEW JAVA INSTALATIONPACK
Sep 20, 2008 | Sun Computers & Internet
Abacus Concepts TV Slideshow Studio for PC Logo
63 people viewed this question
Top Abacus Concepts Computers & Internet Experts
David Payne
David Payne
Are you an Abacus Concepts Computer and Internet Expert? Answer questions, earn points and help others
