Question about Polaroid TDX-02610B LCD TV
My screen went black, One minute it was fine I left the room for about 10 min. and when I returned the screen was black, but it still had the sound. I pushed some of the buttons on the remote and lost the sound now. With the screen being black I can't use the menu to get it back. HELP...
  • 11,361 Answers
It is either the backlight inverter board is bad or it is not getting the 24vdc from the power supply module, you will have to do some checking inside.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 07, 2010
JVC LT-52P789 no picture just sound
If this is an LCD TV, show a flash light on the screen from a safe distance. If you can see picture, it means the backlights have gone off and the TV might need servicing.
Aug 23, 2012 | JVC LT Televison & Video
My daughter was on my dell inspiron 1501 laptop, all fine, i asked to use it for 5 minutes, i unplugged it from the adapter and used it in another room, i returned it still on my daughter plugged it back...
For the first problem, try reseating the memory and the battery, see if any thing happens if you leave the battery out and plugged in using the AC adapter only.
Good Luck.
For the second problem, try removing the battery for about 10 minutes then after installing the battery power up and see if the display if full again, if so grate, if not, you will probably need to have a tech fix it, as either the display is bad or maybe the connector inside the laptop became loose and should only be repaired by a qualified technician.
Good Luck.
Jan 01, 2009 | Dell Inspiron 6000 Notebook
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Very faint picture but sound is fine on my 50" Zenith plasma
Sounds like the Z-sustain board went bad. You will need the board replaced so make sure you find an LG authorized servicer.
Dec 02, 2007 | LG 50PX4DR 50 in. Plasma TV
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
I have suddenly lost the picture on T.V. but still hear audio of program...
sounds like your input board went out. I had the same problem on the ILO version of this panel. Got a replacement part off of Ebay. Search for Ilo plasma on ebay and it will come up
Sep 08, 2007 | Tatung P42BSKT 42 in. HD-Ready Plasma...
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Polaroid TDX-02610B LCD TV Logo
327 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
