Question about LG WM1814CW Front Load Washer
Water is all over the floor from the washing machine. What could be the problem
  • 31 Answers
Water pump, hose or tub.. depends when you noticed water. After it was filled? during draining or filling? Also a clogged drain will cause backwash. Holes in tub from rust will leak out water, water pump cracked can leak water or hoses to drain or to washer not sealed or cracked. Overfill from a faulty fill valve can also do that, but then you'd see lots of water all obver on that one.
Posted on Jul 07, 2010
Just bought it and want to know how to fill it with water
gee think you need to hook the water lines up on the back of it
Jun 16, 2015 | Washing Machines
My washing mschine is dumpng water
Check the water pump for hose connection that hose should be the one going to the drain not the floor
Nov 17, 2014 | Washing Machines
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Put my washing on at a 60 degree wash for 1 hour 40 mins. Went back to machine several hours later, there was tiny amount of water on floor and machine had water in it but the wash had not progressed any...
Sounds like a blockage perhaps the filter needs cleaning or pump blades jammed...If its a Hotpoint then filter is middle of sump hose connected to the drum....
Jan 06, 2011 | Washing Machines
When starting to wash water goes straight out of
The drain you are putting the drain hose into needs to be at least 30 inches above the floor. You probably have the drain hose to low or laying on the floor for this to be happening.
Jun 09, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Water on floor when running, but hoses aren't leaking
never fear i to had this problem and by simply closing the door the water doesnt go on the floor. happy washing mr fixit.
Apr 26, 2009 | Washing Machines
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
LG WM1814CW Front Load Washer Logo
549 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
