Question about Panasonic DECT 517 Cordless Phone
Have a panasonic KX-TG7321E which won't ring when someones calling but if i know someone is calling i can pick up even though it is not registering an incoming phone on the handset screen. It can make outgoing calls but for some reason won't receive them.
4 Suggested Answers
whosale
  • 24 Answers
SOURCE: Panasonic KX-TG5632 one handset high pitched constant ringing
you are getting feed back because of too high of a level. Turn your volume down on that handset and the squealing should go away
Posted on Dec 29, 2008
cnavarro
  • 2460 Answers
SOURCE: Hi: I have a Panasonic KX-T7420
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Posted on Feb 12, 2011
  • 259 Answers
SOURCE: Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Posted on Nov 23, 2011
    Panasonic KX-T7630 not ringing when someone calls
    Look for setting that controls the ring.
    Jun 15, 2017 | Panasonic Lands Phones
    How can i do two way on panasonic 5.8ghz
    These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
    If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
    To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
    If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
    To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
    For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
    The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
    If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
    I hope this helps.
    Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
    Our office has Panasonic KX-T7433 phones installed, but no one knows if they have a voicemail option, when someone rings the phones just ring out although messages are stored showing the numbers that have...
    If nothing answers extension 165 then you probaby don't have voice mail. You can look for something as simple as a TVS-50 or a TVA anything sytsem (US part numbers). Ebay has deals, but check back here before you dive in. You can probably pick up a system for less than $300.
    Carl
    Oct 14, 2010 | Panasonic KX-T7433B Corded Phone
    My phone rings a half a ring then stops. The
    you more than likely have "short rings" turned on, in the options of that phone. you'll have to go into the options menu, and look for setting that pertain to ringing and / or rings or ring length.....DON'T change DTMF tones though, that'll get annoying, as thats what you hear when you are calling someone else. hope this helps.
    Sep 21, 2009 | Panasonic KX-T7633 Corded Phone
    Phone won't ring when people call. it goes straight to msg
    wellcome,all you need to do is to unscrew the phone and change the ringer to another one.
    Jul 26, 2009 | Panasonic KX-TG2740 Cordless Phone
    Hearing a "music" when a call is made
    I think I know this one, so please rate this a FixYa!
    Do not pick up the handset. Press PROG press each line button TWICE. Press the Down arrow on the NAVIGATOR button. It will play ring tones in choices 21-30. Press ENTER to save.
    You have to do that for each line you want to ring differently.
    Carl
    Mar 20, 2009 | Panasonic KX-T7630 Corded Phone
    No dialtone
    If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
    Jan 19, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
    Cant retrieve incoming calls from someone elses extension
    Of course you picked the feature with conditions :-)
    From the intercom 40 picks up any incoming call. 4* picks up trunk calls, and 41 plus ext number picks up a specific ringing phone.
    The condition is that an extension can block call pickup by dialing 7201.. 7200 clears it.
    Carl
    Nov 14, 2008 | Panasonic Lands Phones
    # of rings before answering
    Check to make sure you do not have distinctive ring option turned on.
    Feb 05, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
    Panasonic DECT 517 Cordless Phone Logo
    197 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    george  peters
    george peters
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
