Question about Magic Chef MCBR440 Compact Refrigerator
My refrigerator creates ice on the inside. I
My refrigerator creates ice on the inside. I cleaned it but it started creating frost. It gets cold but not enough.
  • 31 Answers
Is the gasket ok around door(s). If yes, then you have more serious issues and depending on age of unit, it may be better to replace then repair. Frost along doors is a sign of where air is leaking in.. if torn, then replace if just a gap, use a hair dryer to reshape, being careful not to keep hairdryer on any one spot too long.
Posted on Jul 07, 2010
When the heat pump is running in the fall, I notice frost build up the next morning. What cold cause this problem?
Heat Pumps and Refrigerators are the same unit running backwards. To get refrigeration you create heat, to get heat, you create frost. The end blower is the thing that either gives you heat or cold air depending on what setting you are choosing.
To stop the frost building up, you just need to cover that area with insulation. The frost is caused by a cold surface that is below freezing point and water vapour in the ambient air.
Nov 19, 2016 | Frost Refrigerators
Have PSS25MGMBB The freezer not staying cold and forms frost on the inside of the freezer compartment wont even keep ice frozen
sounds like the defrost heater might be going out, you can order a new one at marcone.com with your model number, very easy to do. You will want to have the unit unplugged for a day or so before you do it, all frost should be gone before you start
Jun 10, 2012 | GE PSS25MGN Side by Side Refrigerator
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
Freezer goes through a cycle and get warm. The ice will start melting and create a mess when the freezer start to cool agian. Temperture in frig and freezer does not hold cool.
Unplug, empty, clean and let set for 24 hours to defrost the cooling coil that is froze solid overwhelming the heater and not letting it work. if the air can't circulate it will not cool. Check door gasket, or tell kids to stop holding the door open as this will cause it to frost up and cause the problem you're having.. Trust me, It works.
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Can't control the Temp. too cold/Ice-Machine over flow
sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water inside bottom of fridge, fridge not keeping a cold
Sounds to me you are having a ice blockage and or defrost problem. When that happens water can not get outside of the refrigerator. If you look inside the rear of freezer you may see a frost line or layer building on rear panel. You may just need to begin manual defrost until we can get a look at the evaporator coils and condensate collection tray. Unplug and begin and let me know your model number. I can help if you like, Sea Breeze
Mar 19, 2010 | Refrigerators
What causes freezer to ice up and the refridgerator not get real cold, with all vents unblocked.
((((( In Lamens Terms ))))) The evaperator gets so cold it frosts up. This is caused because freon is compressed and shot out into the evaperator making it cold. There is a fan circulating the air over the evaperator to cool the air in the freezer. As this continues, so much frost can start to block the air flow. (( so what they did, is put a heater in there with a timer so it would defrost the evaperator every 8 to 10 hrs, so the air would keep flowing )) Now if the heater quits working then it will frost and creat a block of ice. The block of ice, blocks the air flow and the air quits getting colder. Also after time the compressor will over heat and shut down untill it cools or burns up.
Jan 12, 2010 | Refrigerators
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Magic Chef MCBR440 Compact Refrigerator Logo
167 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
