Question about Dell Wireless Keyboard Optical Mouse w0147
Wireless key board & mouse
I have a wireless dell key board & mouse. i can not do any work because the mouse is not moving on the screen. i replaced the batteries on the board & mouse , i reset the board & mouse still not working.
    Genius:
  • 1,354 Answers
  • Decide where the keyboard will be placed, whether it is on your desk or a table. Spend a little time experimenting with positions and placement to make sure your wrists and arms will be comfortable. You should consider ergonomics before you set up the keyboard to avoid repetitive motion injuries later on.
  • Step 2 Install the batteries (usually three AA) in your wireless keyboard. Replace the cover securely so the batteries are connected properly. Turn the keyboard on.
  • Step 3 Get out the wireless receiver that came with your keyboard. Position it close to your computer, but not closer than about 8 inches, as the computer itself can cause interference with the wireless signal. You will also want to set the receiver away from other interference-causing devices, such as radios, TVs and telephones.
  • Step 4 Ensure that your wireless receiver is no more than about 6 feet away from where you plan to set your keyboard.
  • Step 5 Insert the CD containing the accompanying software into your computer. A dialog box should appear on your screen. If the install instructions don't pop up right away, manually access the CD by double-clicking its icon or selecting it from the Start menu.
  • Step 6 Plug the wireless receiver into a free USB portwireless key board & mouse - mag-glass_10x10.gif on your computer. If you don't have any ports remaining on your computer, you can use an external USB hub instead.
  • Posted on Jul 07, 2010
    Having replaced batteries on a Dell mouse and keyboard, switched on keyboard and mouse not working. Dell support window says both connected? Cannot move mouse to acknowledge message saying that new device...
    If the keyboard is working, try the "tab" key or a combination of the "tab" and "shift,ctl or alt" key.
    You should be able to move the cursor to highlight to Ok message, then hit return.
    Dec 29, 2010 | Dell Wireless Keyboard Optical Mouse w0147
    CANT ENTER MY PASSWORD TO GET IN MY COMPUTER KEYS NOT TYPING ON SCREEN ITS LIKE THE WIRELESS KEY BOARD IS NOT RESPONDING
    My advice would be to put new batteries in the keyboard and see if that works, failing that, pick up a wired keyboard and mouse to log in to your system then re-connect the wireless set to re-install the drivers.
    Jun 04, 2010 | Dell Wireless Keyboard Optical Mouse w0147
    Wireless mouse not working on Dell Dimension 8400
    you need to press the button on the wire that allows the mouse to sink at the same time as the button on the mouse
    Mar 10, 2010 | Dell Wireless Keyboard Optical Mouse w0147
    When trying to type on my Dell Wireless keyboard, nothing shows up on the screen. I have tried changing the batteries in the keyboard but this has not helped.
    press the connect button on the underside of the key board with an ink pen be gentle. Also move the transmitter a bit closer to the computer.
    Jul 21, 2009 | Dell Wireless Keyboard Optical Mouse w0147
    Dell latitude d820 xp: Mouse inputs are moving
    Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
    Jul 15, 2009 | Dell Latitude D820 Notebook
    Mouse pad and keyboard wont do any thing, i can plug in a wireless mouse and the mouse will move but the key board still doesent work
    Good morning! please check/review the cable connector connections of you're mouse & keyboard, it might be interchanged to its proper port terminal. If still not working, try to use another mouse & keyboard. best regards
    May 09, 2009 | Computers & Internet
    I have just installed a brand new microsoft wireless key board and mouse to my dell and the key board will not type the comand buttons do work the mouse works
    Make sure you install the Intellipoint software that came with the keyboard. If you have done this then try resetting the keyboard by pushing the reset button that is either on the back or bottom depending on model. Hope this helps.
    Jan 25, 2009 | Dell Wireless Keyboard Optical Mouse w0147
    Wireless Mouse a Problem
    Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
    Dec 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
    Just moved keyboard and mouse not responding.
    If you have wireless keyboard mouse try standard ones and see if they work you may get it off power mode
    Jul 31, 2008 | Dell Wireless Keyboard Optical Mouse w0147
    Dell Wireless Keyboard Optical Mouse w0147 Logo
    316 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
