Question about HP Officejet 4355 All-In-One InkJet Printer
My ink will not move to the side when I open the
I'm trying to replace my ink, but the ink cartridge will not move to the side when I open the cartridge door. what to do?
    President:
  • 1,138 Answers
Just make sure the printer is on when you lifted up the top cover for the ink cartridge holder to move to the right side.
You may also try this, try copying a blank paper, look inside the printer when you see the ink cartridges move in the side, disconnect immediately the power cord at the back of the printer. Now lift up the top cover and replace the ink cartridge.
Posted on Jul 07, 2010
Cartridges won't move
turn off open cartridge unit and try to pull the whole print head. some units you can move only when off. if too hard then its locked. make sure cartridges are set correctly in place if it has a lid make sure its closed( for printer head not printer)
Mar 25, 2014 | Canon PIXMA Office Equipment & Supplies
I cannot stop the ink cartridge holder to stop in the correct positioo to replace the cartridges on my epsom cx5500 printer
Hello jgw_cansdale,
Welcome to Fixya.com!
If the Ink light (fon3_66.gif) is flashing that means one or more of your ink cartridge is low on ink, and if it's steady it means one or more is out of ink. For Epson printers, there are lots of ways to identify whether your printer is out or low on ink. For today let's just stick with the printer itself.\
Remember: A flashing fon3_66.gif means LOW ON INK, and a steady fon3_66.gifmeans OUT OF INK.
1. Open the scanner bed by lifting it up just like opening a brief case. By doing this you should now be able to see the carrier area this is the area were the ink carrier or ink holder moves left and right,
2. Press the Ink button. Now remember flashing means LOW and steady means OUT of ink.
If the Ink light is flashing, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is low on ink. pressing it again will point to another if you have multiple cartridges that are running low, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
If the Ink light is steady, and you pressed the Ink button the carrier or ink hold will move under a small arrow just right above the carrier to point to you which ink cartridge is out of ink. pressing it again will point to another if you have multiple cartridges that are out of ink, if not it moves directly to the ink cartridge replacement area were you can pop the carrier's lid open to access the inks.
Regards,
Deathschythe33
Aug 22, 2011 | Office Equipment & Supplies
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
Need to replace ink cartridges and the printhead
Lift the door then unplug.
Slide your fingers under the cartridge carrier and check for paper debris or other obstructions. If none are found try sliding the cartridges out gently to the middle then replug and see if this resets it. If that doesn't cure the problem unplug again and move the cartridges to the opposite side of the bar as far as it will go then replug.
Now close the lid and wait for a self check. If nothing happens you may have a broken belt.
Mar 07, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have all full cartridges, I have tried cleaning the heads multiple times, still i can not get any printing..not even the head alignment will print
try to reseat the ink cartridge, that means take it out, re insert the same cartridge if it is with ion 6 months, if more than 6 months, replace it w/ brand new, the ink might dried up already.
follow this:
Press the Setup button and select Ink Cartridge by pressing the fontu1.gif/fontd1.gif button, then press the OK button. Confirm the messages on the LCD panel and press the OK button to start the ink cartridge replacement.The ink cartridges move to the replacement position.
Make sure that the document cover is closed, and then open the scanner unit.
Open the cartridge cover. Pinch the sides of the ink cartridge . Lift the cartridge out
put it back in the printer.
Close the scanner unit, then press the OK button.
then print a nozzle check
Feb 10, 2010 | Epson RX620 All-In-One InkJet Photo...
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Feb 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Replacing black inkjet cartridge
are you trying to change the cartridges while the printer power is in the ON position? If not, plug the printer in and open the cartridge cover and the bottom bar should move down and then open the top cover over each ink cartridge and pull the ink cartridge toward you.
Good luck
Aug 02, 2008 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
115 people viewed this question
Seeker5211
Seeker5211
