Question about Sharp CV-P10MX Air Conditioner
The air conditioner won't cool the room
THe unit is not cooling as well as it did last season. Is there a filter that I have to change?
  • 31 Answers
Not change, just check to make sure clean, you can run water over them to clean.
Posted on Jul 07, 2010
UNIT WILL NOT COOL. FAN AND HUMIDIFIER WORK. THIS IS ONLY THE SECOND SEASON USED AND THE UNIT HAS NEVER BEEN SITTING UP AND NEVER LAID DOWN OR TURNED UP SIDE DOWN. WHAT IS THE PROBLEM?
A portable air conditioner may not cool for several reasons. Check the filter by removing the unit's grill and clean the filter.
Also check for clogs in the evaporator or condenser coils by light vacuuming. Make sure the evaporator isn't frosted over, but if it is, allow it to defrost and normal operation should resume.
Lastly, ensure the ambient temperature is lower than your AC's set temperature, as this can prevent cooling. However, if all of these steps fail to resolve your problem, the compressor may be malfunctioning, and in this case, the compressor needs to be replaced or repaired.
In summary, if the air won't cool, remove the grill and clean the filter. Clean out any clogs in the evaporator or condenser coils by vacuuming them and scrubbing them lightly with an old toothbrush. And since fan is working, you compressor might be defective.
I hope the above information is clear.
Regards.
Jun 24, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
Tip
Air Conditioning Tips & Tricks You Must Know!
  • Try setting your thermostat between 72°F and 78°F. Each degree setting below 78°F will increase your energy consumption by approximately 8%. As you can see, that can add up to a lot of money over a year.
  • Inspect and clean both the indoor and outdoor AC/Heating coils. The indoor coil in your air conditioner acts as a magnet for dust because it is constantly wetted during the cooling season. Dirt build-up on the indoor coil is the single most common cause of poor efficiency. The outdoor coil must also be checked periodically for dirt build-up and cleaned if necessary.
  • Check the refrigerant charge. The circulating fluid in your air conditioner is a special refrigerant gas that is put in when the system is installed. If the system is overcharged or undercharged with refrigerant, it will not work properly. You may need a service contractorto check the fluid and adjust it appropriately.
  • Use bath and kitchen fans sparsely when you are running the air conditioning system.
  • Reduce the cooling load by using cost-effective conservation measures. For example, effectively shade east and west windows. When possible, delay heat-generating activities, such as dishwashing or baking, until the evening on hot days.
  • Try to not use a dehumidifier at the same time your air conditioner is operating. The dehumidifier will increase the cooling load and force the air conditioner to work harder, which in turn increases your utility bill.
  • Over most of the cooling season, keep the house closed tight during the day. Don’t let in unwanted heat and humidity. If practical, ventilate at night either naturally or with fans.
Room Air Conditioning Units
  • The unit should be level when installed, so that the inside drainage system and other mechanisms operate efficiently. If possible, install the unit in a shaded spot on your home’s north or east side. Direct sunshine on the unit’s outdoor heat exchanger decreases efficiency by as much as 10%. You can plant trees and shrubs to shade the air conditioner, but do not block the airflow.
  • Set the fan speed on high, except on very humid days. When humidity is high, set the fan speed on low for more comfort. The low speed on humid days will cool your home better and will remove more moisture from the air because of slower air movement through the cooling equipment. Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing electricity use.
  • Set your air conditioner’s thermostat as high as comfortably possible in the summer. The less difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be. And don’t set your thermostat at a slighter setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Don’t place lamps or televisions near your air-conditioner’s thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
Proper maintenance of your air conditioner will also save energy. Be sure to do the following:
  • At the start of each cooling season, inspect the seal between the air conditioner and the window frame to ensure it makes contact with the unit’s metal case. Moisture can damage this seal, allowing cool air to escape from your house.
  • Check your unit’s air filter once a month and clean or replace filters as necessary. Keeping the filter clean can lower your air conditioner’s energy consumption by 5% to 15%.
  • Occasionally pass a stiff wire through the unit’s drain channels. Clogged drain channels prevent a unit from reducing humidity, and the resulting excess moisture may discolor walls or carpet.
  • *In the winter, either cover your room air conditioner or remove and store it.
on Aug 19, 2010 | Heating & Cooling
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
On the "super" cool setting, it's not cooling the room too well. Is there a filter that needs to be changed?
There should be an air filter located behind the grill of the unit. This filter should be cleaned once every two weeks while the a/c is in use. Hope this helps
Jul 24, 2010 | Emerson Quiet Kool 10GV13 Air Conditioner
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Room does not cool down
It may be low on freon or have a leak, I'm not sure if that particular unit has Service Ports on it to enable a recharge, consult your Owner's Manual for any Troubleshooting Tips. www.goldstar.com
Jun 05, 2010 | Goldstar KG6000R Window Air Conditioner
Won't cool room off
Check the filter if the filter is plugged the unit will work hard and have trouble cooling the room off.
Jun 01, 2010 | Samsung AW0501M Air Conditioner
Whirlpool window air conditioner 20000 btu's not cooling properly
It is possible the cover needs removed and the condenser coils are in need of a good cleaning. (the one in the back that is outside).This assuming the compressor is running and it has not developed a leak and lost the coolant charge. Eric
Aug 15, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Instead of cooling the room, the back of the AC forms ice
Change the filter. It doesn't have the proper air flow across the coil. Hope this helps. Good luck
Apr 27, 2009 | Danby DPAC8020 Air Conditioner
Sharp CV-P10MX Air Conditioner Logo
241 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
