Question about Toshiba Satellite A305-S6853 Notebook
When i turn on my computer, the screen won't work
When i turn on my computer, the power button light up and the other lights around the keyboard are obviously receiving power, but the screen remains black
  • Toshiba Master
  • 1,606 Answers
Your back-light system may be out or it could be the video section of the main-board.
The backlight is the usual suspect when you see these types of symptoms. To check and make sure there are a couple of things to check. The first way is to let the laptop boot. You may not see the video but it will boot normally to either the login screen or your desktop depending on how your windows was configured. Now what we want to do is get close to the screen towards an edge. You are looking for images of the log on or desktop. They will be very ghost like or hard to make out but they will be a normal screen, you may even be able to see your mouse cursor move around. You can use a a flashlight and hold it near the edge. That can sometimes make it easier to see if you get the right angle. If you can see the image this confirms that the backlight is out. If you can't see anything you should check with the next step before doing anything.
The second thing to check is to hook up the laptop to an external monitor. You should see a normal image. You can use your laptop like this if you had to. If you do not see a image then the problem is the video section on the main board.
If you have warrenty this is covered if it is the backlight or the mainboard. So check that first. If not then you can repair the backlight for $50 to about $150. This is one of those repairs that isn't hard to do. There are several stores that will sell the parts for either problem. If you do a search for laptop repair parts in your search engine you will find several. You can usually find one close or one that has a better price. Most will have instructions or videos on how to do the repair so look at those before ordering any parts just to make sure its something you feel comfortable doing.
With the cost of new laptops being so low you need to keep in mind that the replacement cost may not be that much more than a repair bill if you have someone do it. By the time you add up parts, labour, shipping and taxes it can get up there.
Posted on Jul 07, 2010
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
Screen won't turn on/Power stays on
To do a power reset, unplug your laptop, remove the battery and hold the power switch down for 30 seconds.
otherwise it may be problem with your screen back light...
Apr 10, 2013 | HP G60-535 Laptop Notebook Netbook...
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
Computer won't do anything, keyboard does not light up, screen is blank
So there is not so much as a BIOS message on screen? Any beeps?
If there is no life at all, you have a CPU/motherboard failure. This may be direct or indirect (e.g. no power to MoBo). Check your connections.
Otherwise, your boot device may not be operating. This is usually a dead or disconnected HDD. Check that it is plugged in. Does it get warm? Can you feel any vibrations from it? It should spin even if your cpu is dead but MoBo is alive.
Oct 26, 2012 | HP Compaq Presario SR2038X PC Desktop
What's your problem?no picture won't turn off
could be any number of things, make sure the power supply physical switch is turned on on the back, when you press the button do you get any power on indication i.e. a light or hear a noise?
Apr 29, 2012 | Acer Aspire™ T180 PC Desktop
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspire™ T180 PC Desktop
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
Am using Win XP When I turn the pc on with recovery disk inserted the Press Any Key to boot from cd" screen comes up but pressing any key does not get a response then it continues on to the sign in...
OK! Lets troubleshoot this together.
First thing we want to do is verify that your keyboard & mouse and plugged into the correct places and are powered up and able to work.
Turn your computer on and look at your keyboard and tell me if any lights are on to show that it has power and is operational.
Watch the keyboard lights until the computer gets to the login page and tell me if the lights come on and stay on? Or do the lights turn on for a moment and then turn off again?
If you do not see any lights, please clarify if there are NO LIGHTS on your style of keyboard or if there are lights but they are not lighting up.
If your keyboard has lights and they are not lighting up at all, then turn off the computer and unplug the mouse and keyboard and swap them around. Then turn the computer on again and tell me if the lights come on and the mouse and keyboard become operational.
Once we verify this we can continue to the next step of troubleshooting. Please report what you find and I will help you solve this.
Nov 08, 2010 | IBM NetVista PC Desktop
Computer dosent turn on..screen is blank with blinking LED
have u tryed
unplug all of your plugs at the back like blow on them like i do to get lil partcals of dust out then plug all back in and mite work or maybee ur power cord is screwed a bit and u mite have to get a new one whats happednd to ur comp happend exactly the same with mine and i screwed with myn for ages and it finaly worked so maybee just try all that n then if that dosent work as drliativ hes a good guy and will help
hes helped me out a few times hes a great guy
Dec 02, 2008 | Smart Modular SV3170A
Toshiba Satellite A305-S6853 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
