Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
Cleaned the unit and it won't turn on? - Frigidaire FAH106N1 Wall/Window Air Conditioner
  • 6,826 Answers
Let it dry out,if it is digital,that is the problem,let it dry out,maybe blow it out with air if you can around the controls.
Posted on Jul 07, 2010
  • 31 Answers
Was it plugged in when you cleaned it? check circut breaker. Otherwise you may have damaged your electronics on the unit.
Spectra oven won't turn on only clean.
What is the complete model number of your unit?
Feb 13, 2013 | Kitchen Ranges
Self cleaning oven won't start
Hi bstetson328 - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self clean option, if it does not turn on then the temperature had tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC and I would suggest contacting a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Pioneer stereo won't play cds
Clean the optical unit and see if the disc turns or tries to turn , if this wont detect or read it is possible that the optical head is faulty and needs to be replaced.
Mar 11, 2012 | Pioneer Audio Players & Recorders
The dehudifier won't come on in and in the digital display the message CH 01 comes up. Any idea what the problem is?
CH 01 usually indicates that the filter is dirty and needs to be removed and cleaned. Turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place.
Thanks for choosing FixYa.
Sep 07, 2011 | LG LHD659EBL Dehumidifier
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
I am receiving the F9 code. The oven will not turn on. I have reset the oven but it still does not work
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Amana ACF4215 Electric Kitchen Range
The red alert light indicates that the filter needs to be cleaned. I have cleaned it but the light remains on. I have turned the unit of and on again but it doesn't change the light. The unit is...
Tunr the unit OFF & unplug it for 15 minutes. Then plug it back in and turn it on. The electronics should have reset and reverted back to the original factory settings & the red light should no longer illuminate, as long as the filter was reinstalled properly.
Hope this helped you and thanks for choosing FixYa.
Aug 08, 2011 | Heating & Cooling
There is a buzzing sound, but the blades are not turning.
SOUNDS LIKE MOTOR MAY BE BURNED OUT.
IF SO, U CAN TURN BY HAND, BUT MOTOR
WINDINGS MAY BE FRIED SO IT WON.T RUN.
U MAY HAVE TO REPLACE. SEE IF U CAN
SMELL FOR BURNED WINDINGS.
Jun 20, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
182 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
