Question about Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB70SS will not start
Troy-Bilt TB70SS Straight Shaft Gas String Trimmer was running fine and I was using it for about 10 minutes. I stopped it to add gas It never started again. Added fresh gas and a new plug still will not start.
  • 10,865 Answers
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Posted on Jul 07, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do i adjust the magneto gap on a Troy-Bilt TB70ss string trimmer.
That is it. It is about that way for anything in the area of the clutch and flywheel. It is a pita but the nature of string trimmer in general.
Oct 22, 2014 | Troy-Bilt Gas String Trimmer TB70SS
Gas dripping out of air intake on troy bilt trimmer TB525EC
The diaghrams in the carb could be starting to stiffen up holding the needle open. Does it start with no choke when cold? Rebuild the carb to replace stiff diaghrams
Oct 24, 2012 | Troy-Bilt 4 Cycle Straight Shaft String...
Can not loosen trimmer head
If it's a straight shaft trimmer the head screws off clockwise. (Reverse threat)
Sep 16, 2012 | Troy-Bilt Gas String Trimmer TB70SS
TB70ss Trimmer runs but does not turn the string
Remove the angle drive gearbox near the string head and spin it to see if everything is moving properly. You may have stripped the gears out of it.
Sep 16, 2012 | Troy Bilt Tb70ss Gas Trimmer
I have a TROY-BILT String Trimmer model TB70SS and I cannot get it restrung when the string runs out. Do you have a manual that shows how to load the string for this model?
Click Here For Your Manual.
If it takes you back to your model number & serial number, simply enter your model number and any random number for the serial. You will be able to access the manuals from there.
I hope this helps.
May 06, 2010 | Troy Bilt Tb70ss Gas Trimmer
Weed wacker runs then quits and won't start for hours
Sounds as if the issue is related to heat. Possible ignition failure when hot. (I see that alot in my shop.) If the unit is new take it to an AUTHORIZED repair shop and it should cost you nothing. Locate your nearest repair shop HERE.
Hope this is helpful,
Dolf-
Oct 18, 2009 | Troy Bilt Tb70ss Gas Trimmer
Too Much String from my Troy Bilt
The majority of the time excessive string feed is caused by one or a combination of one or more of the following:
String wound backwards. Seems simple enough, but happens to the best of us.
Missing or improper spring.
Lubrication ANYWHERE on the shaft or inside the bump head assembly. This item should be clean and dry..but never lubricated.
If you know the model number on your particular trimmer, that would assist in troubleshooting.
I hope this helps.
DROPNDEAL
Jul 12, 2009 | Troy Bilt Tb70ss Gas Trimmer
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy Bilt Tb70ss Gas Trimmer Logo
883 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
