Question about E.Digital Odyssey 1000 MP3 Player
I have lost my eDigital Odyssey 1000 charger.
I have an eDigital Odyssey 1000 but I have lost the charger/adapter. I need to find out what the output voltage was of the original charger, so I can get another one.
Charger output voltage and amp
Search google for a charger for your laptop model and look at the specifications shown for the chargers available. The voltage may also be on the bottom of the laptop and also on the battery pack.
Jun 28, 2016 | Computers & Internet
Wall charger replacemnt
Go to amazon.com and search "Trio Stealth G2 charger"
or, if you can't wait
check the OUTPUT voltage and amperage on the old charger (for example, it could say: "5.0 VDC --- 1000 mA" (that means 5 volts, 1000 milliAmp), and find a standard charger with same voltage, and same or higher amperage.
Dec 21, 2015 | Trio Stealth G2 7 inch Tablet with 8GB...
Lost adapter for nebulizer, can you use any AC adapter that uses the same output neeeded?
Hi...I just looked on Ebay and there are some AC and DC chargers for your nebulizer on there.
Dec 13, 2012 | Omron Healthcare Inc Omron AC Adapter for...
Lost the charger to my notebook
What's your notebook model? Not all ac adapters work. Before making a purchase, make sure the following three conditions meet.
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19.5V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Here blow is a store specialized in laptop ac adapters, have a check.
http://www.chargerbuy.com
Dec 04, 2011 | Computers & Internet
The new adapter is not compatible with the battery more info: laptop-batteries.com.au
you will need a genuine dell charger and look on your old one to see what pa it is if it says pa-12 then you need the same one again
Feb 22, 2011 | Dell Inspiron E1705 Notebook
Can a nx9110 charger /ac adapter work on an ibm thinkpad t30
Thefollowing three conditions should be met for you to use a charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop. Pleasecheck carefully before using nx9110 adapter on t30.
Dec 11, 2010 | IBM ThinkPad T30 2366 Notebook
I lost the AC adapter for my Vector Compact Elite 300 amp jumpstarter (veco11). What output adapter should I use to charge it? I have a 12 volt that doesn't seem to work.
You need about 14 volts to charge a 12 volt battery. The original charger MAY have some form of current limiting in it.
ALSO pay attention to the polarity of the charger.
Oct 30, 2009 | Electrical Supplies
Battery Chargers
Hi , we'll need the make and model to find out for you.
Apr 08, 2008 | Office Equipment & Supplies
Where can I get a new charger, I lost mine
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter)
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | TruTech PVS12701 Portable DVD Player
E.Digital Odyssey 1000 MP3 Player Logo
55 people viewed this question
Top E.Digital Audio Players & Recorders Experts
steve cannon
Level 1 Expert
Robert Graf
Mai Lor
Are you an E.Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
