Question about Fisher and Paykel GWL11 Top Load Washer
Washing Machine shuts off by itself during cycle
It went from shutting off late in the cycle to early in the cycle. It happened after we washed a comforter which we have done before and it was fine. There is a weird smell where the water has not drained too.
  • 31 Answers
Not sure what you are saying.. if washer is off balance, it will shut off, check legs are secure to floor and unit is leveled. If washer lid isnt sealed or lid switch is bad it can shut off at spin or start cycle. Depends on unit model. The smell can be a burning belt from a heavy wet comforter or you have mildew from water not properly drained from unit.
Posted on Jul 07, 2010
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
My washing machine (MAH4000AWW) stops during wash cycle. Door sometimes opens. If I tape it shut, this doesn't happen. What needs to be replaced?
You may need a new lid switch. It may need to be cleaned as may the lid switch actuator. Go to repairclinic.com for help in diagnosing the problem for your particular machine.
Dec 17, 2009 | Maytag Washing Machines
Water won't shut off during wash/rinse cycles & overflows
the clear tube going from the tub to the pressure switch probably came undone or has a hole in it
Apr 24, 2009 | Washing Machines
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Front loading frigidare washing machine
Check breaker only one breaker are function recock it the two breaker try to start it .
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Shutting off early
Check out http://www.maytagfrontloadsettlement.com. This sounds like the same problem many other Maytag customers have encountered (including me).
Dec 07, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Washer goes into unbalance mode
Check the springs and spring mounts,(might be broken or not on right), also could be something wrong with the balance switch (where the tub hits the switch).It could be mis aligned or defective. Check the springs first.
May 13, 2007 | Whirlpool AWM6120 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
225 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
