Question about Fuji FinePix A350 Digital Camera
The camera lens doesn't open completely, and the picture is blurry. it's ok sometimes, if i turn it off and on, but this doesn't always work.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 07, 2010
With the Finepix a350, after having dropped the camera and used it in tough environments I had tried silicone spray around exterior of lens barrels which seemd to help. However, the jamming persisted and would only be overcome momentarily by knocking the camera body on different sides until the lens would open.
After reading the above susgestions, the compressed air (CleanSafe aerosol can) realy seems to make a difference in clearing out and minute debris.
Posted on Sep 12, 2010
Blurry screen and pictures
sounds like the camera was dropped, if you look ate the camera from the sides, and the lens don't look square to the camera body, grab the lens and force it into alignment, you might hear a little POP, and thats sometimes good..BUT call your local camera shop and ask what the average cost to repair ? and always check your camera for recalls !
Jay the pump repair guy
Feb 08, 2014 | Kodak EASYSHARE M340 Digital Camera
Dslr camera
What make and model camera? Which Sigma lens? Do you have autofocus turned on, both on the camera and the lens?
Jul 01, 2013 | Sigma Cameras
Lens won't retract completely. Picture is blurry.
I wish I could offer some simple solution, but the lens has somehow gotten damaged and is no longer able to focus or withdraw into the camera body. It could be as simple as some sand in the lens, but even that will require a trip to a camera repairman
Sep 12, 2009 | Kodak EasyShare V803 Digital Camera
Blurry pictures, HELP ME PLEASE!
I'm currently having the same problem. :[
You might want to check and make sure your lens in on the "A" setting and not "M". This can be found on the side of your lens.
Nov 24, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Pictures are extremely blurry, like smeared. Also now lens won't close when off
Hi
If the pictures are smeared, then your CCD is bad and needs to be replaced. The "E:18" error message is a generic message meaning your lens is defective... so it sounds like you need the lens completely replaced.
I would look for a defective camera online and make a good camera out of the two. If you would like to have your A75 repaired, I don't have current pricing for a lens assembly but I can get it for you.
Good luck from Darntoothysam com, and let us know if we can help.
Thomas
Oct 08, 2008 | Canon PowerShot A75 Digital Camera
Blurry screen
it is most common problem you lens focus is out this could be mechanical or a electronical problem.
Sep 22, 2008 | Canon PowerShot A75 Digital Camera
PICTURE LOOKS BLURRY
  1. Adjust the focus
  2. clean the lens
  3. check it again, if still doesn’t work, please let me know how long have you had this camera.
May 13, 2008 | JVC GR-D22U Camcorder
Buzzing sound
the problem is with lens.this sometimes happens if cam becomes victim with water.
there is some buzzing noise when the shutter of lens gets opened or closed.
please clean the lens with the solution once.then you can make out of blurs.
Apr 04, 2008 | Samsung Digimax S630 Digital Camera
Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Frank!!
Oct 07, 2007 | Olympus Stylus 700 / 700 Digital Camera
My camera is blurry..and it takes blurry pictures..How can i fix this?
Gently clean the lens or get it cleaned at a camera store. I suspect fingerprints on the glass. If this isn't it, the camera's infrared sensor may be malfuntioning or dirty, or the lens assembly is not functioning properly (warranty).
Sep 13, 2007 | Samsung Digimax D53 Digital Camera
Fuji FinePix A350 Digital Camera Logo
461 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
