Question about MGE UPS Pulsar Ellipse 300 (89301) UPS System
Mg Ellipse 300. All three frontal lights flash with beep. This occurs repeatedly. I have tried disconnecting ups for a longtime & letting it "settle" down. Still the same. I have also tries pressing the frontal button for a longtime but no good.
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
Washer shut down & flashing ce light appears
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 25, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a flashing power light and the computer won't turn on it looks like some kind of error code but i can't seem to find out what the code means
Each bios type used has its own code. They will flash a series of flashes and or beeps that will help narrow down the problem. These are alled POST codes or power on self test but are refered to as beep codes sometimes.
The code will repeat until you power down. So you need to run it long enough to get the code. The code will be in the pattern of a space then a series of long and or short beeps/flashes and then a paue and the will repeat. As an example three long beeps usually indicates a memory problem. A long beep being about a half second or so.
Once you know the beep code a simple search for beep code on google or bing will get you a chart showing the meanings. At that point you will know if it is a simple fix or a shop job.
Jul 05, 2010 | Toshiba Satellite A55-S106 (PSA50U0NE02E)...
When i push the power key it beeps and two lights appear then it shuts off its been a while since ive charged it
Visit:Peeplo.com/Free+Repair+Manual & im almost sure as i have a disability scooter when its not in use use a decent trickle charger they can be left plugged in for up to 3 months,so your batteries are fully charged all the time & plug back in even if you do a 100 yards trip,lets be honest the batteries are not cheap,so get the most out of them.or if not in use for any period after they are fully charged disconnect them.
May 11, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Light on front flashes red, beeps, won't start
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 12, 2010 | HP Compaq dc5100 PC Desktop
After switching on time elcb tripping
UPS systems by their very design leak current from the input filters to ground.
Some UPS systems will not work on earth leakage equipment.
You could try it on a regular socket, it may work just fine.
Of course, if their is any doubt consult a competent technician first.
Thanks for using FixYa, please let me know how it goes.
Aug 24, 2009 | MGE UPS Pulsar Ellipse 300 (89301) UPS...
No Sound/ lights flashing on Amp
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Jul 09, 2007 | Sony XM-752EQX Car Audio Amplifier
MGE UPS Pulsar Ellipse 300 (89301) UPS System Logo
74 people viewed this question
Top MGE Computers & Internet Experts
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
