Question about Dishwashers
My 12 yr old Miele has the drain block light flashing. Manual says it blockage or no water. No blockage found in drain. Seems like its a solinoide type problem. Found the filter looks ok didn't take apart. Does anyone have any ideas? Mike
    President:
  • 1,515 Answers
Hi Mike, what you need to do is check where the drain hose connects to the garbage disposal. Remove the clamp and hose and look inside the hole of the disposal to see if it is clear. This is where they will normally plug up. Does the unit fill with water when you turn it on, or can you even turn it on? If not, are you able to hear the solenoid click to start the water filling? If it clicks, it has power and should open to start the fill cycle. If you can get back to the solenoid valve, you can check it and the supply line if you loosen it. Turn the water valve off first under the sink, and take the line loose at the solenoid.Crack the water valve to see if there is water there. If so, and the solenoid clicks and opens, it should fill. Check these things to see and keep me posted. Get back to me and let me know what you have found.
Sincerely,
Shastalaker7
PS Check inside the hose at the disposal also when its off.
Posted on Jul 07, 2010
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Kenmore elite dishwasher, less than 1 yr old. Wont drain. I have pressed ''Drain'' on the keypad, motor/pump runs but no drainage. If blocked, where? Can I clear it without having to dismantle and remove...
take a shop vac and attach it to the ond of the drain hose to remove the water and if you are checking the drain pump then it has to be pulled out from under the cabinet.
if the unit is less than a year old just set it up for service it will not cost you anything
Apr 10, 2010 | Dishwashers
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Hello , The inlet/drain light on my dishwasher is flashing , I have mislaid the manual can you explain how I can rectify the problem please , I am assuming something is blocked. Regards Georgina Cooke
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
Jun 24, 2009 | Miele G892SC SS Dishwasher
Miele dishwasher g664 12 years old maybe?
if the water drains into a bucket then the blockage will be in the drain spigot under the sink where the drain hose connects.hope this helps.
Mar 14, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
