Question about HP Deskjet D4160 InkJet Photo Printer
Our Deskjet D4160 had a jam and the paper was pulled out. the paper feed button is blinking and does nothing when we push it. We have restarted the computer, unplugged the printer. What can we do to get it to work?
    Genius:
  • HP Master
  • 1,354 Answers
Hi
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jul 07, 2010
Yellow light blinking and I cannot print
Most likely, the light that is blinking is the Resume light.
When this happens, you should check the following conditions:
The printer might be out of paper.
Place paper in the input tray, and then press the Resume button.
There might be a paper jam.
The printer cartridges are not installed correctly.
Mar 05, 2011 | HP Deskjet D4160 InkJet Photo Printer
Computer sees the printer, but the yellow arrow on the printer flashes but will not feed paper when pressed. persists even when printer is shut off and restarted
You may not have enough paper in the tray or it isn't positioned so that the feed rollers can pick it up. (Sometimes humidity changes can give the same effect.) Also check for paper jams.
In case you have a document stuck in the printer's memory, you should unplug the printer and the USB cable from both the printer and the computer.
I hope this helps,
Dec 08, 2009 | HP Deskjet D4160 InkJet Photo Printer
HP deskjet 1280 paper jam
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
Sep 11, 2009 | HP DeskJet 1280 InkJet Printer
Cannons450 paper jam- removed paper but yellow light keps flashing and nothing prints
At the printer icon cancel/delete all print jobs.
Turn it off by unplug the power cable, and the then turn it on.
If its still blinking, push once the on/off button or if there is any paper feed button
Sep 06, 2009 | Canon Office Equipment & Supplies
Flashing yellow light not allowing me to print
just put in new cartridges in paper full,no jams
Jul 13, 2009 | HP Deskjet D4160 InkJet Photo Printer
How to dislodge a paper jam
turn off your printer.
Carefully pull out the paper.
And run the printer.
Jul 11, 2009 | HP Deskjet D4160 InkJet Photo Printer
HP Deskjet D4160 InkJet Photo Printer Logo
305 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
