Question about Fedders A6Y18F7BCOM Air Conditioner
Air condition wont turn on
Checked brakers...everything fine but ac wont turn back on ..performed reset and plug test and it when u press down the reset botton or test botton nothing happens and the green light on the plug wont turn green. left it unplugged to see if it will reset itself... but no luck so far
  • 31 Answers
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Posted on Jul 07, 2010
LG filter light stays on
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Air Conditioning Boca Raton
Jun 12, 2016 | LG Heating & Cooling
My Frigidaire AC unit doesn't want to turn onafter plugging it in
Thank you for your inquiry, Eddie!
From the information you have provided your Frigidaire air conditioner is not turning on after you have plugged it in. I have identified a few possibilities of what could be causing the problem with your air conditioner to be the control panel or power cord. You may be able to perform a reset on your air conditioner by unplugging the power cord and pressing the reset button. You should hear a click and then press the test button. Once you plug it in it should start. If your air conditioner does not start I would suggest contacting the manufacturer for any additional assistance. Hopefully this information is helpful. -Matt
Feb 05, 2015 | Frigidaire Heating & Cooling
Air conditioner won't turn on. I turned it off
Check the thermostat to make sure it is set for cooling and calling for Ac. Check outside to make sure fuse for disconnect if any is blown .if everything check out then open cover and check contactor .If contactor is pulled in and nothing run check capicator .
Mar 05, 2018 | Heating & Cooling
Printer won't work at all. ON button is lit, but won't go off when pressed, and a test page won't print from the printer itself!
Try unplugging the power cord and the PC cord for 2 minutes then plug the AC back in before connecting the PC. If that doesn't work, unplug the AC cord again and hold the power switch on the printer in while plugging the AC cord back in.If it doesn't work, try performing a semi-reset:
Remove both the cartridges and then perform the reset.
Perform a semi-full reset on your PSC 2200 by holding the button
combination given below, while plugging in the power cord.
CAUTION: A semi-full reset will reset or clear the following
information:
* Return the user settings to the factory defaults.
* Delete language and country settings on some models.
* Fax logs.
* Fax headers.
* Fax speed dial information.
Press and hold "#" and "6" buttons while on the front panel keypad,
Now insert the cartridges back. Try printing a test page from the printer itself now. If it's OK, it means that the printer is OK. If not, there could be a hardware problem with the printer.
Feb 04, 2011 | HP PSC 2355 All-In-One InkJet Printer
I have a 1998 Saturn SC1 1.9 LT. SOHC. CODES: P0341 and P0401. P0341 Set when vehicle was first starting. Coolant temp:2 not moving. No load P0401:Set when 33% load and 58 km/hr. What I have noticed: High...
CODE PO341 IS CAMSHAFT POSITION SENSOR SIGNAL RANGE PERFORMANCE CONDITIONS. CODE PO401 IS INSUFFICIENT EGR FLOW DETECTED CONDITIONS. CLEAN CARBON BUILD UP OUT EGR SOLENOID PORT HOLE IN THE INTAKE MANIFOLD.REPLACE THE EGR VALVE SOLENOID GASKET.ANY TIME DISTURB REMOVE GASKET.IF YOU REUSE OLD EGR VALVE GASKET YOU WILL GET VACUUM LEAK CAUSE HIGH IDLING PROBLEMS. WHEN REPLACING SPARK PLUGS. USE WHAT FACTORY CALL FOR.YOU NEED AC TYPE PLUGS. IF THEY WHERE PLATINUM PLUGS YOU HAVE TO REPLACE WITH SAME PLATINUM PLUGS.
Jan 27, 2011 | 1998 Saturn SC
I got brand new GE air condition and accidentally I pushed test button located on plug (So green light on plug turned off). I tried to start my AC by pressing reset button. But somehow it?s not working....
That is a circuit protector...just like what you would see on a bathroom outlet. It is possible the switch is bad and when you pressed test...it stuck in the open position and will not reset. I would unplug unit and firmly press reset from a couple angles. You may end up getting a new switch for it. Sorry for your inconvenience.... If brand new maybe you can return it?
May 13, 2010 | GE AJCQ08ACB Air Conditioner
As I was cutting weeds away from my outdoor ac unit, I accidentaly cut through a small wire that has a red and white inside of it, we wired them back together and still have no ac or heat or air, we just...
first try turning off the power to the furace for 15 sec and tunr it back on (reset the computer) you may have blown a control fuse on the contol board inside the furnace, turn off power and becareful of hazardous voltage conditions
Aug 15, 2009 | Intertherm P3RA-048K Air Conditioner
Kenmore Model #731893 Room Air Conditioner
Does you air conditioner have a GFCI on the end of the plug if it does there is a reset there.. let me know if it doesn't and you want to go deeper?
Aug 07, 2007 | Kenmore 73189 Air Conditioner
Fedders A6Y18F7BCOM Air Conditioner Logo
446 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
