Question about Jacuzzi Pool & Spa
Need a operator and service manual for a seven seas hot tub standalone unit. M/N EM-190 or SPI-6-968-1
4 Suggested Answers
  • 127 Answers
SOURCE: I WANT DRIVERS FOR USBAV 190 POUR SEVEN HOME p
http://members.driverguide.coid=205824m/driver/detail.php?driver
you need to sign up for free account
Posted on Jul 22, 2010
  • 293 Answers
SOURCE: kde možem zohnat nabijačku na
Hi and thank you for using fixya:
What is your problem?
Thanks
Posted on Nov 01, 2010
uspartscente
  • 717 Answers
SOURCE: it wont run no lites
The wiring diagram for most control boxes made today are located on the inside panel of the control box.
If this doesn't blow the circuit breaker when you turn the GFCI on then you most likely have a bad circuit board.
US Parts Center
Posted on Aug 18, 2011
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
Which position do i connect the water on the tub model american standard 6060lc.020
Uhm....i.dont understand....are you asking about how to install a tub faucet, a tub, or a drinking fountain? Never the less, hot is always on the left from the users perspective. Mount it close to the drain or on an acrylic surround for drop in installation. And as far as the drinking fountain goes. You're screwed.
Jun 18, 2014 | Ragalta Thermo Electric Hot/Cold Disp -...
My hot tub is not coming on at all and is giving me a Pr code. What can I do?
please follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical panel or the electrical panel . Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
Nov 26, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
It wont run no lites or any thing. has power into control panal.nothing hums buzzes or any thing,want a diagram to figure this out,model number 12-322-322m thank you this is a seven sea hot tub
US Parts Center
Aug 17, 2011 | Home
Kde možem zohnat nabijačku na
Thanks
Nov 01, 2010 | Health & Beauty
LEAK @ TUB BEARING NEED TO KNOW HOW TO REMOVE AGGITATOR
Hello shortschip, See this Post and I think it will get you started (old nickname dh1200s). I believe the FAV6800AW/FAV9800AW use 6207-2rs bearings in the outer tub. I have not replaced so I can?t say for sure. The Service Manual which will take you thru removing the outer tub and Clutch Pulley to remove the spinner assembly. There is a special tool needed to break loose the ¾? nut to remove the Spinner Assembly. I heard of someone removing that ¾? nut with a impact tool. Let us know how you make out The FAV6800AW/FAV9800AW Service Manual for reference. Sears Parts Direct for reference. Check ebay for the bearings. Rich
Oct 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hot tub not heating any hotter
It sounds as though the temp. sensor isn't operating correctly. The tstat may have the ability to turn the unit on and off but it may not be sensing the correct temp. I would have a service perfessional come out and check for a short and also that the tstat is operating correctly not just turning on and off. I wouldn't try and bypass due to safety concerns on a hot tub.
Mar 29, 2009 | Home
1993 Mercedes 190 E Defroster problem
chances are a blend air servo motor is not operating and a door is stuck open which lets the hot air from the heater core out through the vents
Aug 28, 2008 | 1993 Mercedes-Benz 190
Kenmore 30" stainless steel tub Model#665-110729120 Serial#FM2101476
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
Apr 10, 2008 | Kenmore 15073 Stainless Steel Built-in...
Pool & Spa Logo
265 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
