Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Dropped external harddrive
Did you figure out what to do? I did the same thing to a simpletech.
Let me know if you have any ideas.
Thanks
April
april@thomasengineering2000.com
  • adrian_benzo Nov 17, 2008
    my simpletech portable hard drive also fell and wasn't recognize anymore by my laptop. but there is still a red light that means the power is on. but the blue light that tells that the drive is active blink only once after plugging it.
    Novelist:
  • 167 Answers
If the drive isn't working anymore just RMA (Return to Manufacturer) it. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Posted on Jul 16, 2008
I have a pininfarina simpletech 500GB usb external harddrive that does not show up in the My Computer folder of Windows Explorer. Tried hooking it up to a different computer with the same results; no...
If it is a new hard drive then it needs to be formatted. You can do this by going into your start menu - control panel - administrative tools - computer management - disc manager. I could be a little off on the wording as I don't have my computer handy, but in the disc management you should be able to right click on the drive in here and choose format. This will format the drive to be used. I hope this helps.
Sep 10, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a SimpleTech Pininfarina 500GB external hard drive. I used it at work on my PC. Now it's home and I want to restore some files using my Macbook Pro computer. How can I restore and access some...
First connect harddrive to mac with usb or firewire cable. Then go to Open a new finder window by clicking on the icon in the Dock. Click on the name of the external hard drive under the "Devices" list on the left side of the Finder window. This will open a window that displays all of the content currently on the external hard drive.
Drag and drop files from your external hard drive into computer. A progress bar will pop up on the screen. When the copying process is complete, the data has been successfully transferred to the computer. Let me know if you need further assistance. Thanks for using FixYa.
Jun 13, 2011 | Computers & Internet
My computer will no longer react to my external harddrive. It's hooked up correctly but whenever I turn it on the harddrive lights go on for a moment then they just turn off and it does not register on my...
first things you have to do is that test the external drive with another system if it works then reload your system i.e format your harddisk and reload it with your operating system.
Jun 12, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech 1tbb harddrive failure
I had the same concern, I try finding drivers with no sucess, change usb cables, and a number of other fixes found on the internet.
Finally what solved the problem was pressing and holding the "One Click Backup" button for 30 seconds.
Apr 27, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
Simpletech 500GB hard drive service center in hyderabad
someone mention to me that its just a laptop drive inside the housing. You can go to fry's and ask. But they will sell you a kit for 20 bucks.The kit contains external power and usb strap cable and bought a seperate housing too. I accessed the ext drive, dragged and dropped all files. But i would check your warranty first, call tech support and double check. IF not what the hey go for it or spends lot of money to retrieve files. Try yahoo.com and under answers and type in simpletech. I dropped mine and recovered all.
Jan 18, 2009 | SimpleTech PC CARD W/ DRIVELINK- SERVICE...
External Harddrive Won't turn on
SimpleTech SimpleDrive Pininfarina 320GB External
I need to replace my ac adapter what is the voltage
6 volts or 12 volts
Dec 10, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Data on my Simpletech 160GB is gone...?
Take the drive out and put it in a new external case. the copying may have been caused by a virus in the computer.
Nov 24, 2008 | SimpleTech 160GB USB 2.0 / FireWire...
Computer wont recognize external drive
The simpletech 1tb drive's case has issues. I had the same problem. It actually quit while I was running a video off the drive. I replaced the case by removing the harddrive from the one it came in and installing it in another case and now it works again.
The first thing I would try is installing the drivers it came with, but failing that you will need to replace it's case.
It has 4 screws to remove, 2 under the silver warranty voiding tape and 2 visable on the bottom side. Remove them, then use a flat screwdrive to pop the case open (gently). Then remove the harddrive.
You will need a case with SATA data AND power cables for this to work.
Sep 26, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 160 Portable doesn't show up
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Jan 22, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
106 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
