Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
GE Adora #DSS25KSRC Ice Maker is very slow in making ice. Is there an adjustment for this?
lsteward68
  • 331 Answers
SOURCE: my ice maker is really
it could be 3 things.
1. The icemaker has a water filter. Has that ever been changed?
2. The water inlet solenoid maybe going bad.
3. The freezer is not freezing the ice. if this is the case clean the back and bottom of the unit as to allow airflow.
Posted on Apr 15, 2009
  • 358 Answers
SOURCE: the ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Posted on Apr 26, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
SOURCE: ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Posted on Jun 01, 2009
2coolrick
  • 560 Answers
SOURCE: Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Posted on Mar 14, 2010
GE adora side by side French door ice maker keeps freezing up and led light blinks. Have had repairman several times for same problem. Can I removed unit to thaw?
  • Possible solenoid fill valve failure
  • Possible failure of the mold heater, not allowing the ice to be removed from the mold.
  • Possible failure of the mold heater thermostat
Aug 30, 2014 | GE Adora (DSF25KGTBG) Side by Side...
On off switch for ice maker
The wire arm that travels up ad down when it dumps ice. Lift the arm to the horizontal position and it should stay there. The ice maker is now off. Push the arm back down and the ice maker is on.
Mar 01, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Our refrigerator stopped making ice. The water comes out fine. How do we correct this problem?
There are two sides to the water control valve=> WR57X10051 Dual Water Control Valve It's possible the side for the ice maker has failed. Try filling the ice maker with tap water and allow it to freeze. If the ice drops after freezing and the ice maker does not refill this will point to needing replace the WR57X10051 Dual Water Control Valve If the ice maker does nothing then that points to the ice maker itself=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Jun 05, 2012 | GE Adora (DSF25KGTBG) Side by Side...
Ice maker quit working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dhjdf
Jun 18, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
My GE adora makes very little ice and water stream is weak
Your problem may be as simple as the water shut off valve behind the refrigerator not being opened fully. Also the refrigerator was pushed back in place did the water line get kinked? If the water stream is weak/low the ice maker may not be filling up completely. There is an adjustment on the ice maker to increase out put but allow 24hrs for adjustment to take effect. The screw is located behind a plastic plug on the ice maker with arrows indicateing which direction for increase/decrease. Also if you have had the refrigerator for awhile it has a water filter that may need replaced.
Sep 17, 2009 | GE Adora (DSF25KGTBG) Side by Side...
THE ICE MAKER IS NOT WORKING. I emptied the Ice bin for a party and now the Ice maker will not make new cubes. The water line is fine and I still can get water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 01, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Adora ice maker not working
Hi: Try settingthe freezer a bit colder. The icemakers are hermally proctected and have to be at zero degrees to make ice. Ice cream should be rock hard. I hope this helps, Jeff
Jun 04, 2009 | GE Adora DSS25KSTSS Stainless Steel Side...
Ice maker not making ice Adora GE
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
311 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
