I just bought 2 new zenith 6500 btu ac's model zw6510r. After plugging them in they both ran for about a minute and quit. They will not run and the green light in the plug is on and the power reset in the plug works. Power will not turn on maually or with the remote!!!
SOURCE: No power to the pannel or unit
I have the same unit and it started to act funny then eventually would not turn on. Suspect circuit board for controls.(I removed the board and played with the connector and checked the components ) All was good and unit is working again still need to find new board Part #cor182k
Posted on Jul 11, 2007
TVtechmaniac
  • 140 Answers
SOURCE: won't power up
This model has had problems with the keyboard buttons on the front panel,causing them not to work and canceling out the remote operation. To verify this,you need to remove the front panel so you can access the connector on the keyboard pc board and unplug the connector.After doing this,see if the remote control is able to turn on the tv (wait for it to power up because with the connector off, the green power light will be disconnected and will not light up when the tv is on) If the tv works, than you will need to change the ten individual switches on the board - part# 432P089010 (or just use the remote only)
Posted on Aug 21, 2007
  • 86 Answers
SOURCE: Haier a.c. will not run 24,000 btu. Window Unit.
1.voltage stabilizer.
2.selector switch.
3 check input wiring.
4 check out put wiring.
Posted on Mar 28, 2008
  • 230 Answers
SOURCE: wont start
It may have overheated or just the oposit, it could have froze. Eitherway there are sensors that will shut off the unit if these conditions exsist. I suggest waiting a while and trying again. Unplug the unit while you wait.
If this does not work your problem is probably more complicated. I would then start by checking any onboard fuses. If you are not knowledgeable about electricity or handy with appliances I suggest hiring a technician.
Posted on Jun 25, 2008
  • 20 Answers
SOURCE: Tomtom go 730 will not power up.Brand new,used a coupla weeks.
you need to do a hard restart. find tiny hole on under side by bracket mount and press it with a tiny paper clip once. you have to look very very close to see it. you can also try to hold down on power button for 5 to 6 sec.
Posted on Dec 28, 2008
Zenith zw6510r will not turn on
The main power supply regulator section circuit has the fault. Check the fuse. Check for any damaged component/s there. You must be very careful when working with power supply section, as most of the components at this section will be very fatal to touch.
Jul 07, 2012 | Zenith B27A24Z 27" TV
Brand new mower died after first start
recheck your fluid levels make sure the spark plug wire is on also is the fuel your using 30 days or newer old gas doe not burn very well in small engines
Jun 14, 2012 | Garden
WILL A TRACE 2012 INVERTER RUN A 15000 BTU RV AIR CONDITIONER
According to specs, they will take a 44 amp AC power surge. Obviously number and type of batteries as well as battery condition , etc, plugged in, not plugged in to outside hydro, or generator all come in to play here, but a 15,000 BTU roof AC will only draw, 15-17Amps AC when compressor kicking in, ( or less on some new models) and should level out at 12 -13 amp draw after. As well, this will depend on proper wiring to and from main panel as well as AC unit, and incoming voltage, AC unit condition ( cleaned and maintained properly) etc.
Nov 06, 2011 | Xantrex Technology Trace Series Inverter /...
I just bought a 1999 Winnebago with an Onan 6500 genset. It only has 45 hours on it. It will run for 15 - 20 minutes with the AC on and then quits. It will restart after a few minutes and go through the...
a 10 year old genset with only 45hrs on it...sound like the carb may need replace. working with these rv units for 6+ years has taught me that you cannot clean one well enough to fix it. you will need a new carb. your local onan dealer can help. when new the warrenty makes known that 1hr per month under load will keep the carb clean and problem free. evaporating gas leaves deposits and eventualy plug fuel jets. no replacement parts are recommended. i've personaly worked on rv's with 200+ hous and no issues at all. hope this helps, good luck...
Jul 12, 2009 | Watts Onan Portable Generator - 5000 ,...
Two brand news ac unit out of box will not work
get a yellow tester from homedepot, it has three lights [ amber amber red ] hat tell you what you have at the plug. takes out all the guess work. you will love
good luck
saw
Jul 09, 2009 | Heating & Cooling
EVerstar Portable A/C
I have the same problem how can i solve this problem>
Sep 03, 2007 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
358 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
