Question about Epson Office Equipment & Supplies
My Epson CX8400 won't turn on. Help?
My Epson Stylus CX8400 printer won't turn on. Everything was plug in correctly. Also, I tried plugging it directly to an outlet and it won't still turn on. I called Customer support and they were not that helpful. Help, please?
SOURCE: just bought epson stylus cx8400
The cartridge (magenta-69) with the new unit was dried out !!
I purchased a new one and everything works fine !
Not impressed !
Posted on Sep 08, 2008
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
  • 11 Answers
SOURCE: Epson CX8400 ink cartridges run out early
Epson gives you a miserable 12 ml of ink. Then it reports empty when there is still 10-15% of the ink left. I saw someone set up a brand new CX8400, print a single 4x6 photo and it said he was out of cyan. I use reusable cartridges from http://www.ccs-digital.com They hold 20 ml, which is 2/3 more ink. The chips automatically reset to full if you take the cartridge out and put it back in, so you get to use every drop. The ink is in a separate container inside the main cartridge. When it's really empty, you pop out the ink tank and pop in a new one. The tanks are under $3 each. I think this is brilliant because it's like refilling only it avoids the risks and mess of refills.
Posted on Jul 07, 2009
YourZEN
  • 820 Answers
SOURCE: Epson Stylus CX8400, Printer, Copier, Scanner. Need manual.
Manual for Epson Stylus CX8400:
Quick reference guide in pdf-format can be downloaded here:
http://files.support.epson.com/pdf/cx84__/cx84__qr.pdf
An overview of all documents and manuals on this site:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=90342&prodoid=63069506&category=Products
Posted on Aug 20, 2009
I have an epson cx8400 and i replaced the black ink cartridge but theres an error message saying that i need to replace other ink coartridges. I just want to print in black, how do i bypass the error...
hello
i have this link below that gives you allinformation about your Epson printer. specifically the manual , required for review to address the issue with the ink cartridge error.
Run a Printer Check A printer check will help you determine if the Epson Stylus CX8400 Series is operating properly. 1. Turn off the Epson Stylus CX8400 Series and your computer, if connected. 2. Disconnect any connected USB cables. 3. Load plain paper in the sheet feeder. 4. Press Setup. 5. Select Maintenance and press OK. 6. Select Nozzle Check and press OK. 7. Press cx7400_cx8400_ug.1.109.1.jpg Start. 8. The Epson Stylus CX8400 Series begins printing the nozzle check pattern. • If the page prints, your Epson Stylus CX8400 Series is operating. Your problem may be caused by your computer, cable, software, or setting selections. Check for additional solutions or re-install your software. If the pattern on the page has gaps, clean or align the print head. • If the page does not print, the Epson Stylus CX8400 Series may have a problem. Check for additional solutions. If they don't work, contact Epson.
general= http://www.epson.ca/cgi-bin/ceStore/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342
manual = http://files.support.epson.com/htmldocs/cx84__/cx84__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Nov 13, 2010 | Epson CX8400 All-In-One InkJet Printer
I have a supermarket till receipt stuck in the works of my epson dx 8400 how can I get it out
***hi there,il be willing to help you on that. ****
If paper is stuck inside, turn off the Epson Stylus CX8400 Series.
Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX8400 Series back on.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson CX8400 All-In-One InkJet Printer
I lost my cdrom software to my epson stylus cx8400
go to epson website. click on support, look for drivers and downloads. You need the driver at very least but they may offer additional software to download that ordinarily would be on the CD. Unplug printer, install driver first, reboot and plug in printer or just follow the msi instructions.
Jan 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus cx8400 won't print web pages
There are 6 downloads for your printer, 5 are software and one is the driver.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=90342&prodoid=63069506&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=20&y=9
The help is free because we are all users like you who hare or knowledge sometimes learned the hard way.
Now disconnect the printer and go to printers and faxes and uninstall/delete it.
Go to add/remove programs and uninstall all epson programs.
Install the driver and connect the printer when told to by install prog.
Install other epson software.
Sep 18, 2009 | Epson CX8400 All-In-One InkJet Printer
Was printing fine. I turned the printer off and it won't go back on. Everything is plugged in correctly.
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
May 03, 2009 | Epson Stylus Photo R800 InkJet Printer
Ink
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
Printer wont install
You need to make sure to install the correct driver for the correct OS.. This Printer is Discontinued product however below link might be able to help you to get your driver...
http://etech.maiila.com/epson-stylus-cx8400-series-driver-manual-and-software-download-including-for-vista
Good Luck...!
Nov 04, 2008 | Epson CX8400 All-In-One InkJet Printer
Can't print to Epson CX8400
I had the exact same problem with the endless blank pages "printing" out.  I have a MacBook Air with OSX 10.5.6.
Before I got a chance to try and delete and reinstall all the drivers all over again, my phone call was answered by a very helpful lady from Epson's support line US: 562-276-4382.
Here's how easy it was to fix: Go into Apple System Preferences, click Printer & Fax. HOLD CONTROL while clicking on the printer on the left side of the screen.  When you HOLD CONTROL, it allows you to choose the option to "Reset Printers".
Click "Reset Printers", and you will see them all disappear.  Simply plug in your CX8400 and click the plus button to add new printer.  It will search for the driver for you if you have an internet connection.  It worked for me on the first try and took only about 2 minutes total!!!!
I'd wasted so much time installing drivers and screwing with the printer before this.  Save your time for things that make you happy!  Share help when you can!
Dec 03, 2007 | Epson CX8400 All-In-One InkJet Printer
318 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
