Question about JVC TD-W254 Single Cassette Deck
When I recorded a cassette, the problem is the stereo is going to mono either left or right channel, and also have low volume problem during recording.
  • JVC Master
  • 5,391 Answers
This sounds like an recording pre-amp problem. Anything common to both channels problem faults are always connected with a device that has both channels going in and out of it. In this case I suspect a recording pre-amp IC.
Posted on Jul 11, 2010
Stereo channels of Xenyx 1202 are very very quiet
It sounds as if the input is too low. what happens if you plug whatever is going into the stereo channels into a pair of mono channels. Or are you taking about the phono stereo tape input?
The stereo channels are line level whereas the other channels have both line and mic level inputs, what are you trying to put through the stereo channels? You must make sure the gain switch is set to the -10dB to get the most sensitivity (the mono channels have about -132dB max sensitivity BTW) You probably need a different mixer or possibly a submixer if you are needing more than 4 low level inputs.
May 06, 2014 | Behringer Music
B2 Pro left stereo channel is Mute
This is not a stereo microphone. There is no left channel. If you are recording into a stereo input, you need to split the input into two mono inputs, and record each channel as a mono track.
Feb 02, 2013 | Behringer B-2 Pro Professional Microphone
Hi i have connected the Samson G-track with my macbook. also i using Nicecast & Traktor for radio broadcasting. when i talk from Samson G Track my voice comes only from left speaker. I try the...
This is because the G Track's Mic signal is on the Left channel and the Instrument signal is on the Right channel. You are making a stereo recording when you should be making 2 mono recordings. Does Nicecast have an option to set the track to mono Left channel? Traktor should, but I haven't used it so I can't tell you where the option is. There's probably a Track Input drop-down or something like that.
Sep 12, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Volume will not raise - does this need a repair? Is this common ? Is there a wonderful set of earphones that would fix this. Office is on a very tight budget.
Try different tapes, if the audio is low from all tapes you can try to used a micro cassette head cleaner at http://www.tvps.com/Products/Certron-MCHC-Micro-Cassette-Head-Cleaner---New__CE-MCHC.aspx other option is to get a really good headset this model is incredible for Mono or stereo units at http://www.tvps.com/Products/ECS-Deluxe-35-mm-Mono--Stereo-Over-Head-Headset---New__ECS-OH3-prd-5MSVC.aspx or just Send an email to service@tvps.com or call (805) 644-9525. Please indicate model, serial and detailed description of problem to service your unit.
Aug 29, 2011 | Olympus Pearlcorder T2020 Desktop Cassette...
Is there a stereo input for the Dell Inspiron 1100 to record?
Yes, the input is stereo BUT you need to configure Audacity to do the stereo capture. Go to File > Preferences. Once in the preferences dialog, go to the third Drop-down menu, and change from MONO to 2-channel stereo. That is.
Apr 27, 2009 | Dell Inspiron 1100 Notebook
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
SONY RCD-W100
Can you please update this with your connections. I assume that you are connecting the turntables to the mixer? Verify that the mixer is set to send out true stereo. What mixer are you using?
Note that most mixers "pan" all of the channels to the center sending out mono to the left and right. In most live shows, it makes no sense to send out true stereo. The left and right are for the speaker chains. In order to get true stereo out of the mixer, you wil need to pan the input channel for the left side all the way to the left and the input for the right channel to the right.
Dan
Mar 17, 2008 | Audio Players & Recorders
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
JVC TD-W254 Single Cassette Deck Logo
136 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
