I have a HP DesignJet 5000 wide format, and I replaced the original ink system with ink container bottles the hold more volume for larger production. After doing so I am getting an air pressure system error. Does anyone have any experience in doing a modification like this and why I may be getting this error thanks
  • yan dikshteyn Jul 07, 2010
    nice thanks ill try
    President:
  • 1,561 Answers
I think this is an error with the air pressure system. The first thing I would advice you do is turn off the power and then open the left side back and disconnect the ribbon cable and the air hose to the tube assembly and then reseat both and try again. I would also suggest you check all hoses back there to make sure none of kinked or broken.
Take care.
Posted on Jul 07, 2010
Mixed ink systeme
Match all your clients' custom colors with the HP Indigo Ink Mixing System. This stand-alone device allows operators to mix a wide range of special colors from a set of base inks. The HP Indigo Ink Mixing System combines state-of-the-art color measurement technology with HP ElectroInk to make color matching a precise and predictable procedure. Fully automated software guides the user through steps of measurement and analysis to determine the best color match to the original sample and to mix new ink-easily and efficiently. If you prefer, special HP IndiChrome Off-Press inks can be mixed and shipped to you from HP at any time.
Apr 23, 2014 | HP DesignJet 3500cp InkJet Printer
Hp designjet 800 does not recognize black cartridge in ink supply station
I see lots of different posts- but not many that are actually helping-
Ffirstly are you using a original HP ink cartrige? ( 3rd party inks have IC chips that are usually not as robust as HP's, If- you've tried a Brand new Never inserted cartridge and still have the same error,you nedd to look at how the plotter recognises a cartridge, the IC chip (found at ink cart bottom) needs clean contacts check and clean the same for the opposite contacts in the plotter- wipe over with a alcohol wipe, allow to dry and try again, if it fails again I would suggest a replacement ISS ( ink Supply Station) a common failure on th Iss gives this exacting fault and may well be the cause, as above the ISS is a Service engineer fit,but can be handled by the customer if they are confident and thorough when following instruction, a ISS will likely cost about $200 so suggest you try cleaning the ink mist from the contacts first,
Mar 09, 2014 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
Designjet T 770 error 87:10
Actually it has to do with a "dirty' encoder strip. The carriage cannot read the strip due to a coating of ink-over spray from time. My suggestion it to call in a Service professional who is familiar in cleaning Wide Format printers. Other areas also are in need of cleaning, lubrication as well. Timing is "Everything" on these babies 60752e95-9503-4f40-8e0c-e67a2ad6b300.jpg
Jan 21, 2014 | HP DESIGNJET T770 Printer
Yellow printhead on my Designjet 3500CP isn't releasing ink
If you can access the printhead, try taking a rag with a small area heavily wet with Denatured Alcohol (this is a cleaning solution that can be purchased at Walmart or most stores with cleaning supplies. Rub the printhead thoroughly with the alcohol for a minute or two, it should help loosen any dried ink. Then try to print or run a print head clean cycle on the printer.
Nov 03, 2017 | HP Designjet CP UV Yellow Ink System...
I have a HP designjet z2100 printer but It stop printing larger banners and now will print banners in a tile format not one contiuos document
Hello.
If the problem occurs from one computer only, remove printer from Printers and Faxes and renistall the driver.
If needed, here's the link for the driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=pl-89035-1&jumpid=reg_R1002_USEN
If the problem occurs from more than one computer, please let me know.
Hope this helps.
Jul 19, 2011 | HP DesignJet 5000 Printer
Errorcode 93:11 on HP designjet 4000
Unable to pressurize the IDS(ink delivery system). Ink Pumping problem.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the
Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing
Cable
Jul 15, 2011 | HP Designjet 4000ps InkJet Printer
HP DesignJet 500PS mixed ink color in tubing
Hi
Think this should be fairly easy. If it's still printing quite happily but just th colours are off, probably means your print heads are fine. Hold onto the new ones and return to store for credit.
All you cand do to flush out the system is to keep printing. Belt out a couple of phots and it should start to come good maybe 1-2 photos maybe 5-6. But should come good.
Regards
P.S.: refer to manual that you do now have all the rite tanks in the rite place.
Dec 29, 2008 | HP DesignJet 5000 Printer
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
13 people viewed this question
k24674
jasbo
jasbo
