Question about Sony PlayStation 2 (PS2) Console
Playstation 3 40 gb blu ray drive broken ribbon cable clip
Help me please? i was turning on my ps3 to switch games and it falied to eject so i opened it to see what was wrong. the ribbon cable to my disc drive was loose i tried to put it back in and i broke the clip on accident. i tried to put it back on and its stuck to the spot where the cable connects. i know the drive works because i was able to eject by holding the cable so that its in place. the clip part is blocking me from using tape or anything to hold it down any advice please?
  • 182 Answers
press and hold eject button for around 15 seconds, it resets the cd drive, hope this helps
Posted on Feb 07, 2009
SOURCE: quantum of solace, on blu ray, previews play fine, film wont
Do need the internet, just go into your settings tab on the intro menu for the PS3 and hit system update. Use the via internet option and it finds the newest version...2.70. Takes a bit to download but, when it's done you get to enjoy watching the otherwise $30 drink coaster.
Posted on Apr 05, 2009
  • 107 Answers
SOURCE: I have the playstation 3
so simple. with the ps3 controller go into settings, accesory settings, bd remote and follow the prompt it gives you. easy done
Posted on May 08, 2009
  • 5 Answers
SOURCE: dose not run the game disc
if the blu-ray is damaged this is a serious problem id suggest contacting sony but they'll probably just send you a replacment
Posted on Jun 18, 2009
  • 2777 Answers
SOURCE: i need a blu ray leans for 40 gb playstation 3
All lenses are the same regardless of the exact model playstation 3. Any playstation 3 blu-ray lens will work. You should be able to find replacements by googling for one.
Posted on Jun 24, 2009
My ps3 dosen`t want to turn on,and I can`t get the cd out?
you will have to open it up and take apart the blu ray drive to manually eject the disk, OPENING YOUR PS3 VOIDS ANY REMAINIG WARRANTY YOU MAY HAVE, also be very careful with the ribbon cable on the bottom of the drive, the ZIF connectors are very fragile and break very easy
Feb 01, 2012 | Sony PlayStation 3 40GB System
Our PS3 60gb, with 4 USB ports is having problems reading the new PS3 games. The old PS2 games still play. When it comes to games like Rachet and Clank or any other new game, it will start then freeze. I...
Hi there, it definitely sounds like the blu ray player. They are relatively simple to fit yourself as long as your warranty has expired. If it is still under warranty just phone Sony and they will replace it.
If you warranty has expired then you can buy a working blu ray drive on ebay for around £60. There is a circuit board that is attached to the blu ray drive, it is extremely important that you keep this as it is paired to your motherboard. Your PS3 will only work with that blu ray circuit board, no others.
To actually replace the drive is pretty easy. On the left hand side of your console there is a warranty sticker covering a little rubber bung. If your system is out of warranty peel back the sticker a little so you can remove the rubber bung. Under this rubber bung there is a small torx head screw, I think a T8 torx but a small flat blade screwdriver will take it out.
After you have removed this screw the whole top of the PS3 slides to the left and comes off. Underneath the PS3 top cover there is another plastic cover with screws all around it. As you are looking from the front of the console there is a marking on the plastic cover that points to one screw that says "S", this is a shorter screw and only goes back in that place. Remove all the screws. Just to the left of the short screw there is a small recess in the plastic casing where you have to push a little black clip back gently while lifting the cover from the back of the PS3. It should all lift forward and come off.
On the right hand side of the PS3 you will now see your blu ray drive. It lifts up but be careful, there is a ribbon cable and power cable attached to it. The ribbon cable is hidden underneath. You have to carefully lift the long black strip that is on the clips where the cable is held. This will release pressure on the ribbon cable and allow you to remove it. You will see the blu ray logic board attached to the back of the drive. Remove this from the drive taking care with a very small connector with a black and red wire, this is the optical sensor wires, remove with care!! Nowafter you have done that you are ready to replace your blu ray :)
Hope this helps and thank you for using FixYa
Aug 29, 2010 | Sony Playstation 3 (PS3) Console
Have a PS3 80GB. Has broken clip that attaches to
i know how to repair this without buying anything, sounds crazy but email me and ill tell you how!!
Dec 30, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 not turning on
The only way you would be able to get your disc is to open up your PS3. I advise you not to if your warranty is intact. If not, unscrew 1 bolt from left side with torx bit. Slide panel to the left. Unscrew 7 more bolts on top along sides and corners. Open from back like a book. Unplug the ribbon of the BD drive by flipping the tab connecting to the motherboard. Unplug the smaller plug from the bottom left of the BD drive. You should be able to figure out how to open the BD drive from there.
Or, another way is, you can just remove your BD drive, and connect it to your friend's PS3 and hit EJECT.
Sep 14, 2009 | Sony PlayStation® 3 (60 GB) Console
2 disks stuck in ps3
You are A ******, try beating yourself with a hammer
Aug 22, 2008 | Sony Playstation 3 (PS3) Console
It's less work and risk to use original Sony blu-ray laser for the Playstation 3 complete with the mechanism. this is the part you need and makes it easier to replace.
Mine cost me £54 . You will need a special hex screwdriver its a T-10 for the PS3 (Make sure its the type with a hole in the centre)
and a set of small screwdrivers .. watch makers screwdriver set is ideal.
and just some regular Philips screwdrivers .
Eject any CD, DVDs you may have in the drive turn off PS3 and disconnect all cables.
The first step is removing the top cover of the PS3 ( IMPORTANT NOT:- this will invalidate any warranty you may have ).
Place your PS3 on a none fluffy and none static cloth to protect it while working.
IMPORTANT NOTE:- Before touching anything inside your PS3 or the
replacement part , make sure that you ground any static from yourself
by touching something metal)
To remove the cover locate the small rubber lug on the left hand side of the PS3,
it is partly covered with the warranty seal. peel off the warranty seal then remove
the rubber lug with small screwdriver.
you can now remove the hex screw using the T-10 screwdriver. then slide
the top cover to the right to remove. this will reveal the main cover.
the playstation 3 main cover has arrows showing the screws needed to be removed. remove them all and note where the short screw goes . if remember correctly it the top right hand corner.
Now care fully lift the cover from the rear upwards and disconnect any ribbon or cables from the the connectors .
put the top cover to one side. the the Blu-ray drive unit can now be lifted carefully
and any ribbon cables or plugs removed from the connectors then remove from PS3
Now you can work on the Blu-ray drive unit... This is the tricky part and is where you need to be extra
carefully because you could mess up your Blu-ray drive unit. take care when removing any of the ribbons
the connectors are very delicate. lift the connector release flaps with a small screwdriver gently
and when replacing any DON'T FORCE THEM DOWN WITH ANYTHING like the tip of a screwdriver. just slide the ribbon in then gently
close the flap down with your finger. the ribbon cables have black marker lines on them so you can see if they are correctly lined up and straight.
This is a video to show what it involves..
if your not confident with type of thing I Suggest
DON'T try it! Take it to an expert.
Jul 09, 2008 | Sony Playstation 3 (PS3) Console
PS3 Blu Ray Drive won't eject
open that **** up,have similar problem,mine was caused because of a sticker on a dvd, couldnt find my warranty,and force eject wouldnt work,i was afraid to open the bluray drive completely,just to the point where i could manually eject the disc and found a round sticky mark on the disc,the sticker is probably still in there,but keeping the ps3 horizontally seems to help,your problem however could involve with the thingies in the driver not being propperly alligned
Jan 20, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
318 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
