Question about Philips DVDR70 DVD Recorder
When I make a recording off my humax pvr hard drive using the phillips R70 and try to play the dvd I get the message "disc empty" although the disc will play on my pc. Please help
    Master:
  • 601 Answers
You might need to finalise the disc first before it will play elsewhere.
Posted on Dec 12, 2011
Can you still hook up a DVD & VCR Recorder through Rogers PVR and record to disc anything you have on the PVR memory to a disc to have a hard copy to keep and free up space on PVR memory????
I think you will have difficulties with DVD or Video tapes that have imbedded copy right signas l if you feed the video cable from old device into PVR s input source. You may find the PVR will refuse to record due to copyright . Does the PVR have a USB port you may be able to plug in a 20 Terabytes USB portable drive into it . I am not familiar with the rogers PVR but check its manual to see if it can.
you may be able to convert the DVD or Video Tape into an MPEG -2 or MPEG -4 format and read it on the PVR using a computer.
Copyright law may allow you to convert the type of media (you must own the rights to use original copy) to another format of media (PVR) for your use only. Check if copyright in your country allows this in Australia it is covered under https://www.comlaw.gov.au/Details/C2004C01235
also see
https://www.pctechguide.com/how-to-transfer-your-vcr-tapes-to-dvd/how-to-transfer-vcr-video-to-dvd-preparation
https://www.pctechguide.com/how-to-transfer-your-vcr-tapes-to-dvd/rip-import-copy-vcr-vhs-video-and-burn-to-dvd-with-nero
Aug 14, 2015 | Televison & Video
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Cannot get dvd recorder drive to read dvd-rw
manual should tell you to use either dvd(+)rw or dvd(-)rw typ disks
Feb 07, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
PHILLIPS DVDR70/051
Wish the lovely couple a lucky married life. Fixya.com
Please download required User Manual of Philips DVD-R70/051 model.
Good Luck.
Sep 29, 2008 | Philips DVDR70 DVD Recorder
Playing recorded DVDs on PC or other DVD player
Hi
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Thanks
T.Boopathy
Aug 23, 2008 | Philips DVDR3455H/37B
Can I record from the hard drive of a pvr
YES.
Connect the PVR to the DVD recorder via scart or RCA phono connection.
Select the relevant input on the recorder, press play on the PVR and record on the recorder.
May 02, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Humax pvr 8000t manuals
You will need Adobe Reader (free) to read the manual
If needed, click Get Adobe Reader on this link
http://www.adobe.com
Here is a link to the manual
http://www.humaxdigital.com/global/products/new_manual/pvr8100t_me.pdf
Jan 02, 2008 | Humax DRT800 DVD Recorder
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Nov 10, 2007 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Philips DVDR70 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
