Question about Panasonic CW-C501RU Air Conditioner
Cold air Hi there, I have a panasonic model cw-500rk. It is working absolutely fine except that it doesn't blow cold air. It seems like only hot air is coming out. Do you have a solution for that or can I put water in the ac.
  • 1,056 Answers
The compressor is not working. Only the fan. No you can't put water on it to make it blow cold air. The compressor is what makes it blow cold air. If you are interested in trying to troubleshoot it let me know. It is not that easy but if you are patient and a little mechanically inclined you may be able to do it.
Posted on Jul 07, 2010
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
Heater blows only cold air. in and out hose are both hot, what could it be.
The door that mixes hot and cold air seems stuck in the cold air position. Check for a vacuum hose leak.
Feb 27, 2015 | 1994 Lincoln Town Car
Heater doesn t work
Your control panel might be broke..
Sep 25, 2013 | 2002 Pontiac Sunfire
A/C fan blows enough air but temperature is niether hot or cold
CHECK YOUR PRESSURE SWITCH. IT IS ON YOUR EVAPORATOR.
Aug 04, 2009 | 1999 Cadillac DeVille
1998 Town Car A/C Blows Hot Air But Is Charged Up
Hi - There may be 2 separate problems. On my 1991 Lincoln Town Car, there is a Thermal Blower Lockout sensor that disables the heater from blowing until the engine temperature reaches a specific temperature. This way if you have vent or floor settings and 90 degrees set and it is winter, you won't get blasted with cold air. When the vehicle warms up, the TBL circuit enables the climate control to blow the hot air. If you use the flr/def instead of the floor or vent control, the TBL should not prevent the heater from working even with a cold engine. On my car, the TBL went bad and always prevented hot air from blowing on the floor and vent settings, even when the engine was hot. Another thing to check is a thermal limitor resistor. It is designed to cut off the blower at very hot temperatures, except if the blower fan is in the hi setting.
As far as the A/C is concerned, can you verify if the clutch is engaging or not? A rapid cycling of the clutch is an indication of low freon. If you are absolutely sure that you are fully charged on freon, I think there are 2 possible causes: (1) Bad pressure switch on the accumulator is indicating low freon that is telling the compressor not to work; (2) a blocked orifice tube.
Aug 02, 2009 | 1991 Lincoln Town Car
A/c blows cold parked then blows hot after a few miles
engine fan not kicking in at right interval to bring air in so its pulling in hot air threw ducts
or you have a disconnected duct blowing all air out not to right place
guages could be faulty or bad a/c relay
Jun 10, 2008 | 1993 Lincoln Town Car
Panasonic CW-C501RU Air Conditioner Logo
187 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
