Question about Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN
Minka Ceiling Fan Doesn't Work
Bought two of the same fans, and are installed within 40 feet of each other. First one I installed worked fine, can't get second one to turn on. Manual said something about turning power on and off and then holding the stop/start button to set remote to a different frequency if 2 fans are installed within 40 feet of each other. Tried this multiple times, but I still can't get it to work. Positive it's hooked up correctly as I've taken it down and installed a light to double check the connections. Any advice? One oddity is that the power switch was a dimmer, but I didn't want to use it to so I wired the power to bypass the switch.
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
SOURCE: light blows when turned on
I had the same issue. Electrician pointed out my bulb was not 120v like it needs but 12v-hence the problem.....
Posted on Dec 21, 2008
mcgyver468
  • 710 Answers
SOURCE: I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Posted on Apr 25, 2009
  • 454 Answers
SOURCE: Minka F719 Lavery Wired fan and fan works but light does not come
The light leg should be hooked to a power source. If you have a separate wire from a wall switch, that's where it should be hooked. Otherwise, you can hook it to the fan leg and operate the light from the switch on the fan.
Posted on Jan 31, 2010
SOURCE: F519-ORB stopped working
the first thing i would check is the wire connections under the cover at celing possible loose connection check wire nuts be carful turn power off befor serviceing ps dumb question is the switch on
Posted on Apr 14, 2010
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
I have a minka aire fan and my remote doesn't seem to work. (UC7084T)
1. Shut off main power to the fan (circuit breaker)
2. Remove batteries from the remote and press all buttons to eliminate possibility of a stuck one. Reinstall batteries
3. Turn on main power and try remote
Jan 26, 2013 | Minka Aire Ceiling Fan
How to change the direction on the Napoli fan ? Right now it is turning clockwise
Some Minka fans have a reverse button (REV) on the remote control. If yours doesn't, there is a slide switch on the exterior of the fan's motor.
Minka has a website with downloadable user manuals at minka.com. Enter your model number in minka.com's search box and you may read the manual there.
Good luck from Detroit, MI.
Apr 29, 2011 | Minka F715-TSP Sterling Walnut Ceiling Fan
3 concept II fans and 3 minka aire remotes wit 3 recievers in a 3 bedroom house all within 40 feet of eachother and remotes keep interfearing with eachother and there are no dip switches on reciever only...
According to the URL at: http://minkagroup.net/Admin/UploadFiles/F518-English.pdf there are dip switches on the fan. They are on the receiver that is most likely tucked away in the bell housing at the ceiling level. Pull the bell housing down and you will find a box of sorts that has the switches on it. This is the receiver.
If this solution is helpful to you, I would appreciate a Thumbs Up rating. Thank you, Paul
Oct 14, 2010 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire remote control ceiling fan problem with dimmer.
Did you ever find a solution to your issue? I have the EXACT same problem and have been looking for an answer for about a year.
Sep 20, 2009 | Minka Aire Ceiling Fan
Apr 25, 2009 | Minka -Aire Brushed Nickel Remote Control...
Fan and light not working
The receiver in the fan might be burnt out,it is at the ceiling in the large base or maybe the transmitter. Do you have fresh batteries in the transmitter?
Jan 01, 2009 | Minka F701-DRB 52'' Ceiling Fan
Minka -Aire Brushed Nickel Remote Control Fan MIA F518-BN Logo
56 people viewed this question
Top Minka Dryers Experts
David Jewell
Are you a Minka Dryer Expert? Answer questions, earn points and help others
