Question about Sony KDFE50A10 50" HDTV
Video lines Remote only responds to power button as the T.V. Red, Blue, Green vertical lines accross the screen. The picture is there but the contrast is very dim. The television takes a bit longer to turn on. This is a 5 year old set. Sony KDF-E50A10
  • Sony Master
  • 8,617 Answers
Very common problem usually caused by a defective B Block.
Posted on Jul 08, 2010
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
Screen goes green with white vertical lines
I think either your red and blue filaments are not fully intact causing the green to take over or you have other electronics like subwoofers too close to your tv.
Try degaussing your tv, it might have a degaus button at the back or check the menu.
If you've tried those things without luck, respond with more details.
Hope that helped.
Jan 01, 2008 | Zenith C32V37 32" TV
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Blue vertical line at reght side of screen
This is normal. Depending on what you have connected to it the lines could be white, black and white specs, or green. Just mode will show the entire picture event the parts that aren't supposed to be seen. I would not recommend that setting. Full is the best mode if you want to see the entire picture in the correct ratio.
Apr 24, 2009 | Panasonic PT-56WX53 53" Rear Projection...
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
I DON'T GET A PICTURE WHEN I HOOK UP MY LAPTOP TO MY TV MONITOR.
on your laptop keyboard, press function button & monitor button at the same time .
Oct 18, 2008 | Computers & Internet
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
No picture, just red-blue-green lines through the middle of the screen very faint.
The PT-53WX54 is a standard projection set and does not have a bulb. It has 3 separate picture tubes. If you have lost the picture completely, not even on-screen menu, then something has stopped working in your set. It could be a video processor, vertical deflection or possibly a convergence problem. The set should be serviced by a qualified tech familiar with the Panasonic projection sets.
Aug 22, 2007 | Panasonic PT-53WX54 53" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
How do you exit service mode?
PANASONIC: Panasonic TV's after 1996 can be set to "Serviceman Mode" with the following remote control sequence: First, select the SET-UP icon and select CABLE mode. Then, select the TIMER icon and set the SLEEP timer for 30 minutes. Next, press the ACTION button twice to get out of the menus. Now, change to channel 124. Then, adjust the volume to minimum (0). You're almost there - Hit the VOL down button on the TV itself (not on the remote) and a red "CHK" should appear in the upper corner. Now, if you press the ACTION and VOLUME DOWN buttons (again, on the TV, not the remote) you will toggle between AGING and SERVICEMAN modes. Select Serviceman mode. The POWER button on the remote control will select one of the five Serviceman Adjustment modes. The modes are: B - Serviceman VCJ SUB Adjustments. These include sub-tint, sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,audio and video adjustment, and vertical size. C - Serviceman VCJ Cut-off adjustments. These include Red, Green and Blue cut-off, red and blue drive, automatic fine tuning(AFT), RF AGC (RF gain control), horizontal center, beam limit,etc. S - Serviceman Options Adjustments. These involce the PIP and clock. M - Serviceman MTS (Stereo/SAP) adjustments. CHK - the mode you first entered. Normal picture and sound, lets you check things over and still have a hotkey into the service menu. There is one more adjustment that isn't in the five modes, it's global. When in either the yellow or red CHK mode, you can press RECALL on the remote control to enter the purity firld check mode. This lets you select a pure white, red, green, or blue screen. A good thing to walk away from if you just want to temporarily freak out the floor manager, but it will be fixed as soon as the TV is turned off. To get out of Serviceman mode, press ACTION and POWER on the remote simultaneously for at least 2 seconds. The TV will momentarily shut off and then comes back on. If this does not help you will most likely need to get the service manual as you should always have that anyway before ever attempting any serve mode adustments. Also do not forget to ALWAYS write down all of the values that you change incase a problem arises. Good Luck
Mar 17, 2007 | Panasonic CT-27SF25 27" TV
Sony KDFE50A10 50" HDTV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
