Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door is stuck on lock. Will not finish rinse cycle.
  • Bosch Expert
  • 414 Answers
The door lock is design to stay locked if the water level is above a certain level, therefore it is possible that you have a blockage in the outlet hoses or an obstruction in the pump. At the bottom of the front panel there should be a flap that will expose the pump and possibly a small hose to empty the w/m manually. Check you manual for the procedure. Follow link if you can't find your copy.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Posted on Jul 08, 2010
4 Suggested Answers
Timon90
  • 126 Answers
SOURCE: door jam!
Probably you need a new doorlock. I really dont have a good answer how to open the door with this problem.
Posted on Jan 24, 2008
SOURCE: door is locked code F21 wont run or cycle or empty water
Try hitting the stop button twice - we are having the same problem but ours isn't draining
Posted on Jan 13, 2010
  • 9 Answers
SOURCE: door stuck shut hot point wd420
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Posted on Apr 04, 2010
I am unable to open the door after the cycle has finished. All my clean clothes are stuck inside and i do not want to force the door.
Sometimes just unplugging it for a couple of minutes and the lock will release. If not then take the front bottom panel off and you should find a little plastic string like, pull it and hopefully it opens. Not knowing model and brand and such makes it hard to say for sure but try these two.
Jul 29, 2015 | Washing Machines
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Whirlpool front loaded getting stuck in wash and rinse cycle
You can remove the top cover of the unit and put your hands towards the door lock and just hit fair enough to get release the lock mostly it will open if not means just break the lock and replace it since if you are technician it will be easier for you if not kindly call the technician and do the service
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Ge quiet by design washer stoped on the wash cycle and I can not get it past to be able to rinse and finish the cycle
most of the time it is the door lock that get broken but it might be that your water valve got something stuck in it.
Jan 02, 2010 | Washing Machines
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
My machine was stuck on rinse cycle now on ventilate...
Try first to continue filling up the water resovoir (UP TO FOUR times) to see if the machine completes the rinse cycle on its own. If that doesn't work contact Gaggia Customer Service in the US at 888-389-4123. Sally there was VERY helpful and should be able to resolve your problem.
Dec 31, 2006 | Gaggia Titanium Espresso Machine
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
376 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
