Question about HP Pavilion s7600n PC Desktop
Mi computer doesn.t detect ani memori card - HP Pavilion s7600n PC Desktop
  • 31 Answers
Memory card reader may be bad or card may be bad. Check card connections as being cleaned. Did it ever work? it may require you to install software that came with card so you can format it to be recognize by your PC
Posted on Jul 07, 2010
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
I have a Panasonic Lumix DMC-FS15 when I switch on it says "built in memory card full" even though I have a 4GB memory card in the camera which is not full. The camera doesn't seem to detect...
Hi, Move the internal pictures to your card and then switch it to record to the card...
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Aug 26, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
Hi..my sd 2gb memory card is detected in any computer or mobile. so please give me a solution for this. i got many important files in my memory card.
If the memory card is not detected in any device be it a phone or a computer then it must have failed in the memory and the only solution for you is to retrieve any data from it by consulting with Transcend service support. please call up their support and get help.
Jul 21, 2011 | Transcend (589307) Media
I have a 4G mini usb drive but the computer doesn't detect it. I tested it in a Dell printer to scan to usb and works ok. I'm running windows XP in my pc. Do you have a driver to install it or any...
Click Start
Right-mouse click My Computer
Click Properties
Click Hardware
Click Device Manager
Look to see that the USB ports are correctly detected, and that their device-drivers are loaded.
Try a different USB device in your computer; if it also does not work, then you have a problem with your computer, _NOT_ with the PNY flash-drive.
May 12, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
My memory card is corrupted i cant see in computer
hi , The problem might be due to any of the following reasons
1 ) Ur memory card must be very old . This usually happens to all memory cards that it won't be detected by the computer .In this case ur memory card is corrupted and nothing could be done .
2 ) Ur memory card reader might me outdated that it doesn't support ur memory card . The solution would be to do a firmware upgrades for the readers .
3) Try to read ur memory card in some other computer . if it is being detected ,please format it . Then u will be from ur problem .will give u the steps
  • Connect ur memory car to ur computer with a memeory card reader
  • An icon with name Removable disc will show up in the my computer page for memory card
  • Right click the icon and select format .
  • Note : When u format ur memory card all the information in it will also get lost so don't forget to take a back up .See to that the computer with which u format ur memory card is free of virus
For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Nov 20, 2010 | Nokia 6630 Cellular Phone
Memory card has a problem after taking important pictures.. displays reinsert memory stick error and wont read on computer either... any idea if photos can be recovered?
Make sure the memory contacts show up a visible clarity. If there is no detection in any of the card readers, inthe camera and inthe PC, it seems likely that your card has some errors on it,
If the card is detecting the memory but is not showing any pictures, the use a file search in the search mode with the drive selected for pictures/images.
If not it will be best to have it checked with a photo studio to concur the findings since you have important images on it.
Sep 23, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Phone wont read memory card
Get a new adapter and try to recover your files with the computer, if it shows empty on your computer aswell, try a file recovery program like recuva which is free http://www.recuva.com/
Sep 11, 2009 | LG Vu CU920 Cellular Phone
Not enough memory to perform operation
DEAR ITS TIME TO HARD RESET UR PHONE. THE TRICK I AM GOING TO TELL U WILL FORMAT EACH AND EVERY PART OF UR PHONE AFTER FORMATING UR PHONE WILL BECOME BRAND NEW
JUST SWITCH OFF THE PHONE
1)PRESS CALLING KEY. STAR(*) KEY AND 3 KEY SIMULTANEOUSLY
2)SWITCH ON THE PHONE WHILE PRESSING THE KEYS( DONT UNHOLD THE KEYS UNTILL I SAY)
3)NOKIA LOGO WILL APPEAER
4)UR PHONE WILL START AND WILL REQUEST U TO ENTER UR CITY.NOW U CAN UNHOLD THE KEYS
5)ENTER CITY,TIME,DATE
UR PHONE IS READY TO USE
Jul 01, 2009 | Nokia N72 Cellular Phone
I want to install driver of jf v30/1gb on my system
I formats the pen drive but due to the electricity cut off, format doesn't complete and pen drive doesn't recognize in computer
Dec 27, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
HP Pavilion s7600n  PC Desktop Logo
41 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
