Question about Sharp Aquos LC37D44U 37 in. LCD HDTV
The tv menu keeps popping up
My Sharp Aquos lc37d44u menu keeps to popping up on its own. Since this has started happening my TV remote no longer works. Also when ever I try and control the volume or change the input the tv menu pops up.
  • Alfred Sch?tz Dec 17, 2013
    I had the same problem. In my situation it wasn't the remote controller, but I solved it by changing a setting in the menu. Go to your menu, choose 'Options', go to 'Demonstration' and turn OFF the demonstration. In my case the tv was continuously giving a demonstration. So turn off the demo and perhaps its solved :)
  • Nick Abbott
    Nick Abbott Jun 25, 2014
    thank you so much thought l had a big repair bill but this solved it
  • 484 Answers
The reason your television keeps popping up the menu is simply because, either the remote or the televisions menu button is stuck.
To test if it is the remote, remove the battery from the back of the remote and try to operate the television from the buttons on the television to see if it works, if it pops up, then it means the problem is not from the remote and its from the television.
Either ways you have to open the remote and clean the panel with naphthalene, then adjust the menu button on it. or you can as well get a new remote for your television if you cannot clean it on your own.
Also to fix the television if it is detected as the fault, get the appropriate screwdriver, open up the television, then try to locate the menu button, then you adjust it and try to operate with either the remote of the menu key on the television.
Once it is seen to be working, ensure that the television is properly coupled back.
Always make sure the keys on the coputer and the television are not pressed too hard.
Take care
Posted on Jul 07, 2010
How do i reset this tv
Just unplug the TV from AC mains wall socket. Replug it after 10 minutes or so. This must make the TV a hard reset.
Jul 11, 2012 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Remote control does not work. If you unplug TV and plug back in remote works, then fails again in a few days.
you may have a firmware bug, check your firmware version GO: Menu --> Digital Setup --> Identification, and if says "S0712041" you have the lasted firmware otherwise upgrade.
if you dont know how do it is 100% recommend you that Please contact Sharp at 1-800-BE-SHARP (237-4277) and report the problem, Sharp will give you a Case # that you will need if any service is to be needed or done.
Aug 10, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Remote doesn't work and repairman said it is the infra-red receiver inside the TV. it is only 10 months old
Still under warrenty why didn't u call sharp,get a new remote often the remote are dead.Not the infared board in the tv.
Jun 22, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Remote sensor on Sharp LC37D44U not working
I have same issue. I see there is a replacement IR board that is covered (i think) for me under 3 yr parts warranty. If you are out of warranty, i found it online for 19$ 8)
http://www.discount-merchant.com/SHARP-NE264WJ-IR-Remote-Control-Sensor-Board-p/1157614.htm
Apr 08, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Sharp AQUOS 37
My friend fixed it but I have no idea how he did it.
Jan 18, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
My Sharp LC37d44u operation manual is partly written in french
The manuals are only available in English. Spanish and French,
Dec 01, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Video set on 480 how do i set it to 1080
Should be able to change HD format by tv remote, cable remote or whatever box controller connected to tv.
Aug 22, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Time Display
Try pressing the button in between the power on/off and P.Info (i+) on your remote a couple of times to change the on-screen display.
Jul 28, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
My dvd player doesn't fill the screen on my Sharp
There are settings on most DVD players as well as TV's that allow you to adjust the type of display you want. Make sure both the DVD and TV are set to the same display type (usually either 16:9 for your type of TV). If that still does not fill the screen you will have to use the Zoom function on either your DVD or TV. This will cut off part of your movie, but should allow you to fill the screen. Most DVD movies will also allow you to choose widescreen or normal viewing from their menu. Again, you will lose a small part of either side of the movie, but at least you will fill your screen.
Jul 07, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Sharp Aquos LC37D44U 37 in. LCD HDTV Logo
1,737 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
