Question about Tatung CRT Touch Monitor
H size does not work
The h size of the tatung monitor does not respond, the picture is bigger than the screen, how could this problem be sorted?
  • tony21ynot Apr 18, 2008
    it is a crt that is used for bally machines
  • Ajemy  Rashid
    Ajemy Rashid May 11, 2010
    is it the CRT or LCD monitor ?
  • 180 Answers
Try tracking the voltage on B+ line.
Posted on Apr 19, 2008
Connect satellite to tatung P42BSKH
hi what sort of satellite box are you using if you have no hdmi use scart lead to av 1 or ext1 hope it helps
regards
shaun
Jan 17, 2014 | Tatung P42BSKH Television
Best wall mount for tatung wm42hdmt plasma monitor?
Usually wall mounts are the same for all units. The only thing to be considered is the size of the screen. Being that your screen is a 42inch you might want to go for a mount which is suitable for that size. Prescribing a particular type might only make you spend more because getting it to your location might cost more. Just get anyone which is made of steel.
Hope this solution has been helpful?
Jun 26, 2011 | Tatung WM42HDMT Television
The picture is too big for the screen. The four buttons will only adjust colour and contrast - not size
To adjust the screen size (resolution) you have to right click on an empty place on Desktop, select Properties and then Settings. Under screen resolution change it to more, until it shows under it 1024x768, or even bigger if you want and it is possible.
Dec 22, 2010 | Packard Bell 15".28 1024x768 Beige CRT -...
My Tatung LD23HL Flat screen will not turn on. Is there a reset? When plugged in the power light blinks Orange.
check the monitor to computer cord, sounds like it might be loose or disconnected. swap another monitor in and go to display properties to see if the tatung is a 2nd monitor. using the replacement monitor redownload the drivers and reinstall. turn off and hook the tatung back and it should recognize it
Oct 09, 2010 | Tatung LD23HL Monitor
I am unable to adjust the screen to fit the monitor. The screen is bigger than the monitor and I cannot reduce the size using the menu buttons on the monitor. Is there anyway to use those options through...
Yes right click on the desktop and click properties, when the window comes up, go to settings, and set to say 800x600, and click OK, this may sort you out.
Also ensure you have the graphics manager installed too.
Aug 06, 2010 | LG Computers & Internet
I have a Tatung lcd flat screen monitor tv. The television comes on there is sound but the screen is black. The tv is 5 years old. What would cause this?
Failed backlight inverter circuits or the power supply for the backlight circuits has failed, you need to open it up and inspect the power suply first, look for bad caps with leaking/bulging tops. Post back what you find so we can guide you further.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Tatung L17AMTN 17" Flat Panel LCD Monitor
When I maximize my document, it is bigger than the screen
Have you tried adjusting the screen properties via Windows? maybe changing the resolution will fix it, and you can adjust the physical screen size too.
Feb 03, 2010 | Dell UltraSharp 2408WFP 24" LCD Monitor
Whan i apply wallpaers in does not apper in actual size instead it appers bigger than actual size which is very odd to look at
your pictures are too large you need to find them and resize them then use them for wall paper or you resolution is not set correctly for the screen size
Oct 19, 2009 | LG L1730SF 17" LCD Monitor
Tatung monitor Power light shows yellow light.
It sounds like your resolution or refresh rate is out of reach for your screen.
Restart your computer (even if it will be manually unplugging the power cable)
If you have no display while your computer starts up; you might have a hardware failure. Swapping your screen out, or plugging it into another computer (that works) will confirm if this is the issue.
If you can see the computer starting up you can press F8 (on your keyboard) continuously just before Windows can start.
Select "Safe mode" so that you will have the basics of screen settings.
Now you can go to control panel, display and click on the Settings Tab at the top. Change your settings to a rather default "1024x768" resolution and change your referesh rate to nothing more than 75hz under the advanced icon.
Hope this helps!?
Jul 07, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Computers & Internet Logo
132 people viewed this question
Top Tatung Computers & Internet Experts
Tony
kj henriksen
kj henriksen
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
