Question about Bose 41213 Headphones
The bose emblem came off onthe left headset that was holding the left ear set on the inside pcs loos fine but the emblem side is broken.Is there a space emblem with the female part for sale?
  • Bose Master
  • 17,130 Answers
Difficultt ot get one except from Bose Corp. I suppose you could have used a instant super glue to past this up. if the earpieces are working fine why not try to do it carrefully as you mentioned it has come off, it can be wedged together with an instant glue. clean the surface and do the process.It should work out economical. I hope it works and looks fine. Good day
Posted on Jul 07, 2010
I have had my headsets for 3 years, they work well, I have just noticed that the left ear pad is detaching from the base. How do I get fixed?
The ear cushions are attached to the earcup with plastic tabs that snap into the plastic in the earcup. The lower snaps may be unfastened. Try pressing the ear cushion firmly to the earcup around the lower edge to refasten the snaps. Do not press in the middle of the ear cushion - you may damage the internal microphone.
If this fails, you will need to remove the ear cushion by pulling it off the earcup and inspect for broken plastic where the tabs are on the ear cushion or where the tabs attach to the earcup. If a tab is broken on the earcup, replacement earcups are available from Bose for $35 per pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
If the plastic in the earcup is broken, you can try to repair it or you can contact Bose about getting it repaired or replaced.
Jun 11, 2011 | Bose QuietComfort 3 Acoustic Noise...
My left ear headset does not work. the right one is fine and the battery is charged,
sounds as if you have a short in the left ear. solution would be to send in to manufacture. Or return to the store.
Oct 04, 2010 | Bose QuietComfort 3 Acoustic Noise...
How can I fix an intermittent sound problem on the left ear piece of the Tri-port on ear Bose Headphones? If I take the ear cushion off and touch the speaker inside the ear piece on the headset using a...
I have the same problem. The first one that I bought last 1 year. I bought another one and the same problem has appeared today. I think this is because they are assembled in China. Cheap and low quality manufacturer that is sold at very high prices.
Apr 01, 2010 | Bose on-ear TriPort Headphones
The small piece of plastic (with BOSE on it)that
You can have Bose replace the headset for you (new w/ 1-year warranty), but if it's past it's current 1-year it will cost you $60.Unfortunately Bose doesn't supply parts for that headset, but you could try using plastic adhesive as a low-tech fix. First Google search result for plastic adhesive:http://solutions.3m.com/wps/portal/3M/en_US/Windows/Doors/Product-Information/Products/Adhesives/Plastic-Adhesive/ .
Jun 11, 2009 | Bose TriPort Consumer Headphones
Bose Aviation headset Series 2 has high-pitched squeal.
Try wearing the headset the "wrong way". The left side of the headset on your right ear & the right side of the headset on your left ear. I have the QC15 with the same problem and it worked for me. Good luck!
Jun 03, 2009 | Bose Aviation Headset X Headset
Slft earcup on QC3 broke off
They will give you a new pair for $100, even if it has been longer than a year...
http://riajournal.com/ria/index.php/2009/04/25/bose-gets-5-stars-in-my-book-for-their-qc3-headphones/
Apr 16, 2009 | Bose QuietComfort 3 Acoustic Noise...
Bose QC3 makes a high pitch noise when i press it against my ear
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When you press the earcup close to your ear, you are changing the size and shape of the air chamber inside of the earcup thus directing more of the speaker sound toward the microphone than the design can compensate for causing audio feedback to occur. You are hearing that feedback. Removing your hand from the earcup should restore the shape of the air chamber allowing the circuits to return to normal operation.
If the feedback occurs too easily when you are NOT pressing on the earcup, then the foam may have weakened/deteriorated and it may be time to replace the ear cushion.
On my QC-3 headphones, I can cause the feedback squeal in both earcups, with the left earcup being more sensitive to the shape change than the right.
Feb 16, 2009 | Apple Bose QuietComfort 2 Acoustic Noise...
A Bose headset is buzzing
The speaker in that Ear Cup may be blown. You should consider replacing the set with a newer one.
If you listen to this with that static noise you risk serious injury to your ear.
Jan 04, 2009 | Radio Communications
Bose 41213 Headphones Logo
163 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
