Question about HP Mini Notebook
HP Mini 110 shut down during scan disc not booting up
Is there any way to do a system recovery without a recovery disc? my daughter shut down the mini while it was doing a scan disc and now it will not boot up
    Champion:
  • 200 Answers
Try hitting the F8 button on the keyboard a screen comes up with several options move to safe mode and hit enter on the keyboard if it boots up to safe mode hit the NO tab when it asks to go to SAFE MODE you then can do a system restore to a date that you know the computer worked....this is a restore not a recovery and you will not loose any of your documents or pics etc....
Posted on Jul 07, 2010
Hp mini "unmountable boot volume"
I ran across the same problem. I used chk disc utility on a hiren's bootable usb. It found and fixed the errors on the main volume and it rebooted up without a problem after that.
Jan 27, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
How to install xp in hp mini 110-3007tu notebook
you will have to get an external usb cd rom and install windows disk. then go to system setup during boot, and make sure that you have usb cd rom enabled on boot devices and make sure it is the 1st boot device.
Jun 04, 2011 | HP Mini 1000 Netbook
My HP mini 110 have a bios password how i reset it?
you have a tutorial here...i hope it will help you
http://www.governmentsecurity.org/forum/index.php?showtopic=2411
Feb 12, 2011 | HP Mini 1000 Netbook
How can you reset a hp mini to factory default
you will have to use the restore function. because of it not having an optical drive
Oct 21, 2010 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
Hp mini 110-1100 tord says bootmgr is missing
if you're running in vista cause vista usually have this error, or other OS, you can often fix it right back up using the original Vista installation disk or other os disk, which comes with a pretty extensive System Recovery Tool that's got lots of options (see screengrab). Set your computer to boot from DVD (using the Boot setting in the BIOS), insert the disc and restart. Vista will prompt you for language and keyboard layout options, then ask if you want to reinstall Vista or repair your installation. You want Repair. From there Vista's System Recovery Tool will take over, and lead you down the road to happy vistages again.
May 10, 2010 | Computers & Internet
How to wipe out HP mini hard drive
To restore your hard drive using Disaster Recovery, follow the steps below.
1. Shut down and power off your HP Mini if it is not already powered off.
2. Connect an external USB optical drive to the HP Mini.
3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc.
4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer.
5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.
Mar 28, 2010 | HP Mini 1000 Netbook
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
I need to restore my HP mini 210 to factory settings
try pressing f11 on boot up to see if you have a recovery manager insalled
Feb 20, 2010 | Computers & Internet
NEED TO UNLOCK HP MINI 110.
Download "Hiren's Boot CD"
Here is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Download the file and burn the ISO image in a CD.Boot your system using that CD. It has lots of tools for repairing Windows, system restore, Data recovery and Password reset.
That's it.
Jan 04, 2010 | HP Mini 110-1037NR Netbook
HP Mini Notebook Logo
346 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
