Question about Minolta PagePro 1250W Laser Printer
Need paper feed gear for Minolta 1250W printer
The driven gear on the paper pickup/feed shaft has a broken tooth. It has 28 teeth with an attached cam. Does anyone supply replacement gears for this printer?
  • 1,219 Answers
Try to find the local minolta service and try to order over them. Or go in few printer repair shops and try to find similar one.
Where are you located?
Posted on Jul 07, 2010
I need to know the size of the center hole on a 19 tooth transmission sprocket for an apc mini chopper Thanks
Why do you need to know the size of the centre hole. That one look in great condition. The size is the size of the shaft it fits on, so you measure the narrower distance, which is between the sprocket tooth that is under the middle of your thumb nail, to the second tooth past your index finger. All this links have info.
  • mini chopper sprockets ' eBay www.ebay.com > Search > mini chopper sprockets Refine your search for mini chopper sprockets. ... Mini Chopper Pocket Bike Parts 19 Tooth Front ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ...
  • mini chopper sprocket in Parts & Accessories ' eBay www.ebay.com > Search > mini chopper sprocket Find mini chopper sprocket from a vast selection of ... Mini Chopper Pocket Bike Parts 19 Tooth Front Chain Sprocket ... APC MINI CHOPPER 48" THROTTLE CABLE ...
  • I need to know the size of the center hole on a 19 tooth ... www.fixya.com > Forum > Motorcycles > APC ... a 19 tooth transmission sprocket for an apc mini ... on a 19 tooth transmission sprocket for an apc ... rear 28 tooth sprocket for an apc mini chopper.I ...
  • Mini Chopper Sprocket and Clutch - DIY Go Karts www.diygokarts.com/chopper-plans/drive-assembly.html ... a torque converter can be used which effectively gives the project an automatic transmission. ... mini-chopper's clutch ... tooth #35 pitch. This size sprocket ...
  • mini chopper parts ' eBay www.ebay.ca > Search > mini chopper parts mini chopper parts 352 listings. ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ... #428 Chain 17 Tooth 14mm Pitch Sprocket Part Gear Go Kart ...
  • Sprockets - PartsForScooters www.partsforscooters.com/Pocket-Bikes-Parts/Pocket-Bikes-Sprocket Mini-Chopper Parts; ... 127-19 . Stock 6 Tooth Front Sprocket with M10x1.00 thread size for 47 and 49cc 2-stroke cag style pocket bikes and mini-quads.
  • Mini Chopper Parts ' Mini Bike Parts ' We Ship https://www.gokartsupply.com/chopper.htm Home >> Parts Catalog> Mini-Chopper Parts. Parts For Mini Choppers Seats - Hand Controls - Fenders. ... SPROCKET 60T #35. 7-1/4" 28.50. 04-470. SPROCKET 72T ...
  • Electra / APC Mini Chopper w 49cc PS engine - Pocket Bike ... www.pocketbikeplanet.com/showthread.php?t=84442
    • 20 POSTS
    • FIRST POST: 2014-06-29
    2014-07-26 · Electra / APC Mini Chopper w 49cc PS engine Mini Choppers. ... Sounds like you got a transmission with slag on the internal gears ... do a search as mini chopper parts.
  • mini chopper bike ' eBay www.ebay.ca > Search > mini chopper bike Find great deals on eBay for mini chopper bike and ... 43CC 49CC APC MINI CHOPPER MINI BIKE MONKEY ... 17 tooth sprocket gear Pocket Bike Mini Chopper ...
  • Rawge's Mini Chopper Information Site - Gearing and Sprockets www.rawge.bravepages.com/minichoppers/speedo.htm Rawge's Mini Choppers ... The Simple Mini Chopper Drive ... you can expect from your mini chopper, given the size of the sprocket on your ...
  • Pagination
  • Apr 08, 2016 | APC Motorcycles
    Copier will not copy feed paper oeven try-justs makes agrinding noise
    Dear
    Pl. do test as per following.
    1- empty paper tray.
    2- pull the toner cart. and close the door.
    3- power ON the printer. Listen the sound of initial motor run,
    (If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
    If all are ok.
    4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
    Thanks.
    Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
    Are the pickup rollers suppose to move up and down?
    The pickup rollers automatically drop onto the paper stack when you push the tray in. There is a spring that operates this. If the pickup rollers are dropping down, you can see this from the back if you look at the gap between the tray and body of the printer then your problem is likely that the bevel drive gear that runs the feed rollers has sheared off. This happens quite often. To check this, pull the printer so that the front edge of the printer is just off the edge of a table. Feel under the front left side (facing the printer) and you will feel a small notched shaft, which drives additional trays. If it does not turn when you try to print a test page, then the bevel gear is broken for sure. Visually confirm by opening the left side of the printer, near the front you will see a little mylar square held on by a single screw. Remove this screw and the mylar square and look closely at the white gear behind it. You will likley see some broken teeth. This is a common failure item on these printers and easily obtained and replaced.
    Aug 27, 2014 | Lexmark T640 Laser Printer
    Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
    That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
    http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
    I hope this helps,
    BuddyMc
    Jul 16, 2012 | HP Office Equipment & Supplies
    HP PSC 1350 printer won't feed paper
    Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
    Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
    13 Paper Jam - but there is no paper inside!
    I have a long solution (possibly) to your issue:
    Error 13 Paper Jam
    • Paper jams can occur in 3 places: Entry, registration and exit.
    • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
    • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
    • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
    • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
    • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
    • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
    • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
    • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
    • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
    • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
    • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
    • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
    All this comes from:
    http://www.fixyourownprinter.com/reference/errorcodes/hp
    Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
    If this information helps, please give me a rating, thanks!
    OpenSource13
    Apr 07, 2009 | HP LaserJet 4 plus Printer
    Noise when scanning document
    Visually check the clutch spring (located on the left side of the pickup roller shaft, just before the gear). If the spring is deformed or broken, replace the entire pickup roller shaft. The part you need to order are shown below. You will also need a small 'C' clip. I do not know if the clip comes ith the shaft or the gear...
    PA03360-Y110
    Pick shaft
    PA03360-Y112
    Pick Bearing ‘M’
    PA03360-Y107
    Clutch
    PA03360-Y106
    Clutch Spring
    PA03360-Y105
    Pick Gear
    Regards,
    Eric F.
    Jan 25, 2009 | Fujitsu ScanSnap Manager
    Lexmark Optra T612
    The broken part is called the bell crank arm part number 56P1228 this is very common. If the printer isn't recognising your tray, remove it and check the little plastic fingers on the left side (half way down the tray) and the metal springs in the printer (left side) which the tray pushes on to.
    Aug 04, 2008 | Lexmark Optra T612n Laser Printer
    Minolta PagePro 1250W Laser Printer Logo
    140 people viewed this question
    Top Minolta Office Equipment & Supplies Experts
    Adorjani Laszlo
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
