Question about Ogio Golf Stand Bag
Womens Ogio golf bag with spring loaded ball pocket doesn't work. Ball pocket "gaps open" and when trying to increase tension on the closure spring element, found out the element is carbon fibre and and not able to bend to increase closure force. Had to sew in velcro at the pocket lip in order to get reasonable closure of the ball pocket. Design stinks. Ogio warranty useless. They wanted bag back (my expense) and then said they'd send a new bag if under warranty, only if the same color if they had one in stock. We bought the Ogio bag because of the particular color combination. Latest "gift" from Ogio is the black lifting ******** the back of the bag disintegrating. Every time we lift the bag via this back strap we get black color on our hands. Short of thowing this 9 mo old bag away, any thoughts as to how to fix the ball pocket situation and to somehow coat or seal the back lifting strap to lock in the color against coming off on our hands.
    Top Expert:
  • 40,357 Answers
Throwing the bag away seems to be the practical solution.
Posted on Mar 09, 2017
How do I get pressure off the torsion bar in order to pull the lower ball joint arm
How to Replace a Lower Ball Joint (short, quick version ...
? 9:27
May 27, 2014 - Uploaded by ChrisFix
Replacing a Lower Control Arm Ball Joint. Learn how to replace alower ball joint by pressing it out of the ...
Popular Mechanics - May 1975 - Page 164 - Google Books Result
Vol. 143, No. 5 - ‎Magazine
I enclose check money order for $4.49 postpaid for each set ordered. ... Conversely, with a tension-loaded ball joint, force on the joint works to pull fast ball joints by taking pressure off primary load-carrier, here the lower ball joint of a torsion-barsuspension system. ... 1 shows the coil spring on top of the lower control arm.
Torsion bar removal - Ford F150 Forum -
Dec 13, 2015 | Cars & Trucks
Suction not working. Opened machine and dirt is not going into the bag even though it is empty. Inside of machine is dirty.
Check that the hose is not plugged. If you hang it over a railing, then look down into it, you won't need a second person. Alternately drop a golf ball or a marble through it. If the ball makes it through, then it can't be clogged.
Mar 08, 2015 | Miele S548 Bagged Canister Vacuum
How to remove spindle to get to lower ball joints on 1994 ford mustang
Jack vehicle up and set on jack stand (on frame) remove tire, brake caliper, place a jack under the lower A arm leaving a small gap between (3/8") the jack and the A arm. Spray area with WD 40 remove the nut from the ball joint. Strike the spindle with a hammer (single blow at a time) in the area were the tapered shaft of the ball joint goes through it and it should release it, then you can lower the A arm down slowly releasing the spring tension.
May 06, 2011 | 1994 Ford Mustang
Can I use dryer balls and/or dryer sheets in the kenmore steam dryer?
Things You'll Need:
* Wool yarn
* Scissors
* Crochet hook
* Pantyhose or sock
Make the Core Ball
Wrap some of the yarn around your fingers.
2. Take your fingers out of the loop you created and close the hole by pulling the yarn through it.
3. Wind yarn around the loop until you form a ball about 2 inches in circumference.
4. Cut the yarn attached to the ball using the scissors. Try to leave a little excess yarn dangling from the ball.
5. Grab the excess piece of yarn with the crochet hook and tuck it inside the ball to prevent the ball from unravelling during the felting process.
Primary Felting
6. Put the core ball into the pantyhose or sock, and tie the open end in a knot. (If you are felting more than one core ball at a time, you can separate them within the pantyhose or sock by twisting the fabric in between the balls before tying the knot.)
7. Put the pantyhose or sock containing the core ball into the washing machine with a load of laundry.
8. Remove the ball from the pantyhose or sock when the cycle is complete. It should now be slightly felted. To increase felting, simply repeat this process.
Enlarge the Ball
9. Wrap more yarn around the felted core ball to increase its size. It's all right if you make the dryer ball a little big at first, since it will shrink over time as you use it. A good initial size to make a dryer ball is around 9 inches in circumference.
10. Cut the yarn with the scissors once you have made the ball the appropriate size. Try to leave a little excess yarn dangling from the ball.
11. Tuck the excess yarn inside the ball with the crochet hook. This will prevent it from unravelling when in use.
Secondary Felting
12. Put the dryer ball into the pantyhose or sock, and tie the open end in a knot.
13.Put the pantyhose or sock into the washing machine with a load of laundry.
14. Remove the ball from the pantyhose or sock when the cycle is complete. The dryer ball should now be felted and ready for use the next time you do laundry.
Feb 28, 2011 | Kenmore Dryers
The ball on the blackberry tour smartphone want scroll at all
Hi, your trackball is probably just dirty from use. You can try spraying compressed air into the gaps around the ball and see if that makes a difference. If it still won't scroll (or scroll well) you can gently pry the ball up a little bit with a pocket knife or small screwdriver and spray air underneath it. That should get it moving again!
Dec 20, 2010 | RIM BlackBerry 8800
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
Ogio Stand Bag - Broken "H" Clip
Mine slide up and down the legs. Not a good design since the weight broke 1 of them. I have not found a replacement part for this yet.
Dec 08, 2009 | Ogio Golf Stand Bag
Am replacing ball joint - is it spring loaded etc.
NO the spring is on the strut the only tension you will havt to deal with is when trying to pull down on the lower A arm to remove ball joint stud from the steering knuckle. the front sway bar goes in the underside of the A arm and this causes upward tension on the A arm.
Sep 27, 2009 | 1992 Oldsmobile Cutlass Ciera
Ogio Golf Stand Bag Logo
2,120 people viewed this question
Top Ogio Winter Sports Experts
Todd Arndt
Todd Arndt
Are you an Ogio Winter Sport Expert? Answer questions, earn points and help others
