Question about LG KU990 Viewty
Lg vewity pc instalation
It says please check COM port then go to the idle screen.. what does this mean, i cant get it to work.. and also how do i use the scroll down the right hand side.. to go down?
thankyou
  • 2 more comments
  • x9graham May 06, 2008
    it says check com port then go to idle screen
  • salohcin May 07, 2008
    The same thing happens to me each time i try it. It tells me to check the com port and to connect in idle screen.
  • auri27 Jul 28, 2008
    I've managed to sync my Viewty once, but for some reason it now no longer works. I get the same screen as above with the com port and idle screen comments. The error message on the Viewty itself says "Cannot Execute. Conflict with (Search)". Any help would be great.
  • gavinmurray7 Dec 08, 2008
    i also cannot get my screen to srcoll down? pls help......
  • 50 Answers
The idle screen is the main screen of your compurter (were all the icons are).
Once you pset up the program on the computer with the disc, you connect your phone and go into the program click on (content) then minimise everthing you have open straight away and wait and it should work...
I hope it was a help...
Posted on Feb 14, 2009
It says please check COM port then go to the idle screen.. what does this mean ?????????????????????????
Posted on Sep 20, 2008
Yay! Solution to the "com port, conflict with search" problem:
Look here for some solutions... http://forum2.mobile-review.com/showthread.php?p=715600
The advice on turning off the phone worked for me. While it is connected by USB, turn off the phone (bottom right hand button on the viewty, wait until the LG PC Suite software doesn't have a connection, and then turn the phone back on (power button in the lower right hand corner). Then press the "synchronize now" button, and good luck. I am so relieved.
Posted on Jul 28, 2008
Not sure about com bit but for the scroll down either click in the center on the scroll bar or click right at the bottom.
Posted on May 04, 2008
Failed to connect phone to pc
I am using LG VU CU920
"Fail to connect to the phone,
Please check the COM port and connect in idle screen.
Aug 26, 2009 | LG KU990 Viewty
Virgin locked LG Vewity
You need to type unique unlock code to remove USIM locked message.
Buy the code from FastGSM KU990 Unlocking Page
Please keep in mind you need sim card from network your phone is locked. Without it you wont be able to insert unlock code.
Jun 26, 2009 | LG KU990 Viewty
Cannot Synchronize My LG TE365 or KS360
remove pc suite completely from ur pc and reload the software using the cd provided with ur phone
May 17, 2009 | LG KU990 Viewty
Cannot connect my LG Viewty to the computer via the LG PC suite
hey.. if u connect ur phone via usb, be sure that ur phone is in home screen, because if not, for example if you connect your phone and you're in your message menu then you will open some apps in your pc suite the message will appear saying 'Fail to connect to the mobile handset, Please check the COM port and connect in idle screen. Due to the multifunction, despite idle screen, it can be failed to connect' now try it by connecting the phone but in home screen mode.. gotcha buddy?? hope soo..
Apr 13, 2009 | LG KU990 Viewty
Can't connect using LG PC SUITE
go back to the main menu of your phone and switch the handset on an off..this should work...because u will be in a search mode for something and you may not notice...this worked for my new LG 501
Feb 02, 2009 | LG KU990 Viewty
SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Sep 04, 2008 | LG KU990 Viewty
Problem with connection wizard
Connect your device to your computer then go to Settings > Control Panel > System > Hardware(tab) > Device Manager > Ports > Disconect COM and connect back, this should refresh the COM connection anad work like before. good luck!
Aug 16, 2008 | LG KG800 Cellular Phone
LG VIEWTY
try changing the comm value. detail ur question for a better answer.
Jul 12, 2008 | LG KU990 Viewty
LG PC Sutie, I can not connect :o(
Firstly You Need To Go In To Phone Settings Then Down To Connectivity Then You Go To USB Connection Mode Switch To Mass Storage.
Then Put Your USB Lead In. Let The Computer Install The Drivers Wait A Few Minutes.
Then Removable Disk J (Normaly J If Not It Will Another One) Then Auto Play Will Pop Up And Your Able To Get To All The Stuff On Your Phone
Criminal-BD =)
Jul 06, 2008 | LG KU990 Viewty
LG KU990 Viewty Logo
249 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
