Question about Dell Inspiron 700m Notebook
Slow running laptop - Dell Inspiron 700m Notebook
    Sniper:
  • 72 Answers
In order to optimize your computer performance, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3. Run Disk check.Disk Check program is used to check and clean any errors on your computer and keep it running smoothly.
How to run Disk Check:Click Start, click My Computer.Right-click on C drive, click Properties.Now, click the tab, Tools. In the Error-Checking section, click the Check Now. Also, check both of the check boxes: Automatically fix file system error and scan for and attemp bad recovery of bad sectors.
Now, You will see a message box that says you can schedule the disk check to start the next time you restart your computer. Click Yes. The next time you restart your computer, it will automatically run through a disk check before displaying your login screen. After the disk check finishes, Windows will automatically bring you to your login screen.Note: Check Disk can take more than an hour to check and clean errors on your computer.
4.Defragment Your ComputerTo arrange the files in a sequential manner, it is recommended to defragment the hard drive. Click Start, click My Computer, right-click Local Disk, aclick Properties.Now, the Tools tab, click Defragment Now. Now, Click first hard disk, click Defragment.Note: Disk Defragment may take long time like 30-40 minute to complete.
5.Stop Programs from running at the startup.
As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.
Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)You will see System Configuration Utility. Click Startup at the top right hand side corner. Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.
In order to remove startup from the registry go the following locations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolder
Right click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.
Restart your computer.
6.Uninstall the useless programs(like gaming softwares, unnecessary toolbars like my web search, myfreeze toolbar)Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
7.Scan the computer with good antimalware, antispyware, antivirus.
http://malwarebytes.org/http://superantispyware.com/
8.Update the drivers on the computer.Click Start, Click Run(Window XP) and type devmgmt.msc(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required).Right click the device, click Properties.Click Driver tab, and click Update Driver.Follow the on screen instructions to complete update.
9.Upgrade RAMWindows can run slow if you do not have enough RAM.Many newer operating systems and programs use more RAM when they are running.How to check RAM.Click Start, right click My Computer, click Properties. You will see the RAM mentioned her.You should have at least 1 Gb(2 GB would be even more better)RAM.
10.Update Windows
Windows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click Automatic Updates tabclick Turn automatic updating on and click install updates.
Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows Update,click Turn automatic updating on and click install updates.
PS: Please leave a positive comment
Posted on Jul 12, 2010
  • 808 Answers
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reg in out registry cleaner
Posted on Sep 09, 2010
How to speed up my HP Pavilion windows 8 laptop
  • Linda, run your anti virus to check system,
  • run disk clean up
  • run defrag
  • running these 3 things could make a drastic improvement
  • press the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | HP Pavilion Computers & Internet
Hcl laptop slow why?
The computer may be running slow for a lot of reasons. A simple quick fix is: Make sure you have an updated anti-virus & malware, run a full scan, delete all the browsing data, temporary files, cookies, make a disk cleanup and defragmentation. This may help a lot, let me know how it works out.
May 02, 2012 | Computers & Internet
My laptop running slow and net browsing very slow my configeration windows7 original ,320 gb HD,3GB memorry
There are several reason for the computer to be running slow for the start please try restarting the computer to safe mode with networking (Steps given below) and check if your browsing speed is better. If your internet browsing speed not better in safe mode with networking then you need to contact your ISP to complain about slow speed.
If it is working fine in safe mode, then some of the software (example: Antivirus / Internet Security / Firewall) is slowing down your computer. Please try removing it. Also try reducing the color scheme, use a non aero theme and see if your comptuer is working fine. If so your processor is not able to take the load of windows 7 visual effects aswell as other programs running in the background at the same time
Mar 02, 2011 | Computers & Internet
Why is my laptop so hot and running all the time? it's only 1.5 years old?? programs are slower too.....
hello,
It is normal for hp laptop to get hot when it is running. my own hp laptop will burn my lap if i put it on my lap while running.
If your laptop is slow, free up space in the hard disk because if the hard is fill up, it can make the laptop to be slow.
If it is still slow, then the laptop is contacted with a virus. scan the system with updated anti virus and delete the virus on your laptop or you format the laptop and re run windows.
Thanks for contacting Fixya.
Jul 15, 2010 | HP Pavillion G50-111NR Notebook
My Netbook is slow than usually,, how can faster it?? Acer Aspire One 532h-2Bb
#1 Make sure your laptop is free from virus, spyware and trojan. A virus or spyware can make your laptop run slow or even damage the whole system. Run a security scan to find out if there are infection files hidden in the system. The slow laptop would be fixed by eliminating the virus.
#2 Remove obsolete programs to release more hard drive space. Laptop slow problem sometimes would be caused by the less hard drive space. To optimize your slow laptop, you can try to delete those unneeded programs, files from the hard disk especially the system disk.
#3 Empty the Recycle Bin to retrieve more system resource. Your laptop slow symptom maybe arises due to the deleted files in the Recycle Bin. If you forget to empty the Recycle Bin, those files in fact still exist on the hard drive and keep eating up your laptop system resource so that the laptop will run slow.
#4 Scan and fix Windows registry. Do you know how important registry is in Windows system? Corrupted, invalid or malicious registry will slow down your laptop and make it run unstable. You would receive many error messages such as dll errors, Internet Explorer errors or blue screen of death in the using of laptop. Thus, it is necessary for you to fix your slow laptop by cleaning registry errors.
Try deleting all unwanted files like Temp files, disk clean up, disk defragmentation.
Jun 14, 2010 | Acer Computers & Internet
The laptop gets hot and runs slow
Two possible solutions to your problem are:
Buy a cooling pad to elevate and flow air around/through your laptop's base.
Use the laptop on a hard, flat surface, and elevate it slightly if possible.
Dec 31, 2009 | Acer Aspire 3610 Notebook
My dell 610 laptop has started running slow
if you are experiencing these and unsure on what to do, better take your laptop a laptop tech, if you feel that you needed a hard drive change, then take it to a tech, have them replace your old hard drive
Nov 26, 2009 | Dell Latitude D600 Notebook
Slow slow slow
Have you tried turning off any background programs that you do not need running in the system tray... Check out your system tray and exit any programs that you do not need.
Nov 30, 2008 | Acer Aspire 3680 Laptop
Compaq Presario v2000 notebook screen ghosts out and system running slow
for the display you can check by connecting the laptop to the monitor through the vga port
Oct 03, 2008 | HP Compaq Presario V2000 Notebook
Dell Inspiron 700m Notebook Logo
210 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
