Question about Dryers
My samsung dryer starts then has the code he, what does that mean
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error HE is a heater error, this issue is caused due to invalid heating temperature is running in the dryer. You’ll need to check for restricted vent system and also check thermistor resistance, replace the part that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 07, 2010
  • dpoland736 Jul 07, 2010
    Ok I clean out all vent spaces where lint could build up now the
    drum will not turn at all...
  • Rylee Smith
    Rylee Smith Jul 07, 2010
    As I said check the thermostat and the belt, please check this repair manual for more assistance. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
My samsung dryer is showing an error code of "OT" what does this mean and how can i fix it?
that code means you have a bad thermistor.if you send the model number whoever helps you can look your dryer up,open the door,look around the opening where you put the clothes in and you'll see a tag with model and serial just need the full model number
Oct 03, 2017 | Samsung Dryers
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
I get an FE code on my samsung WD0704RQQ short time after setting the machine on dryer mode. Please help as my manual doesnt have the code and its meaning.
http://appliancejunk.com/forums/index.php?topic=17042.0
I SUGGST REMOVING POPWER, SHUT OFF BREAKER, THEN RESET, IF IT DOESNT HELP IT WOULD NEED SERVICE
Apr 14, 2016 | Samsung Washing Machines
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
www.repairclinic.com/...Dryer/...-/Samsung-Dryer-won-t-start-DV448A...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/How-To...Dryer/...---/Dryer-won-t-sta...
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
I have a samsung DV220AGW I'm getting an error code of AE or RE. The dryer will spin and heat up but after about a minute it will stop and display the error code. I've had no luck finding...
Hello Dan;
My name is Peter. I am a retired field service appliance technician.
You have a air flow problem. This will shut down the dryer.
AE= Air Exhaust. There is a hot air distribution manifold in the back of your dryer. This is an elongated cover plate. At the smaller bottom is the blower hot air discharge and at the top is the hot air discharge into the dryer. At the bottom of the manifold is where you are plugged up. This is a common problem for just about all dryers. It is plugged with lint. This is item #17
The manifold is held in place with several screws and easily removed. Unplug your unit before the start of any work.
You may also have a rotary fan wheel that is jammed with lint.
This is more difficult to access. It will require the removal of the dryer top and front panels.
There are also several sensors that may shut your unit down. But for now I would go with a plugged up exhaust manifold.
25281118-sy2vaml5ip4mff3cv0drpm3g-2-15.png 25281118-sy2vaml5ip4mff3cv0drpm3g-2-24.png
Nov 13, 2014 | Samsung Dryers
Anyone know what code t0 means? Dryer will start but never finish drying clothes regardless what cycle you're on.
To = Thermistor Open error.
The Thermistor resistance is very high.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Replace themistor if out of range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Samsung DV337 Electric Dryer
Samsung dryer gets a to code
The thermistor or thermal fuse is about an inch long and is inside the rear of the dryer and is usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Sep 03, 2009 | Dryers
Dryers Logo
18 people viewed this question
Top Dryers Experts
