Question about JVC HR-S9500 S-VHS VCR
JVC HR-S7600U VCR flashes AUTO and doesn't stop. Pressing power and unplugging the unit doesn't work. I've never used the programming function (to tape shows or anything). Anyone know how to make it stop?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Unplug for 48 hours.
Posted on Jul 16, 2010
VHS won't work
Had the same problem on my JVC vcr/dvd combo unit.
You need to turn off the timer function. I did this by making sure my remote was in the "VHS" mode...turn the swith from TV to the right (found on the remote in the upper left corner...an then hit the "vcr" button. Then point the remote at the VCR unit and hit the No. 4 button (timer turns off). Your unit should not have the red timer displayed and you should be able to play your tapes okay.
Hope this helps.
Jun 11, 2009 | JVC HR-XVC27U DVD Player/VCR
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
Setup Menu Unavailable for JVC HR-XVC30U
There were several screens that were unavailable and there seemed to be no obvious solution so I treated it like a PC and rebooted the unit. In terms of this unit, it meant unplugging the unit for an hour and then plugging it back in. All functionality is now available once again.
Nov 12, 2008 | JVC HR-XVC30U DVD Player/VCR
Unit won't turn on, goes into standby, flashing "auto"
The mechanism is not "shutting" when power is applied. This step is necessary for the unit to operate. Would suggest a complete belt replacement and cleaning....accordianman
Apr 26, 2008 | JVC HR-S9500 S-VHS VCR
Flashing auto display - won't power up
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
Apr 25, 2008 | Televison & Video
JVC AV-48WP55
Many models of this time frame have an auto index function, and will alway record the pulse when entering record mode from "stop" or "pause". To prevent this unit from recording the pulse, try backspacing the tape, then press "Play", then press "Record" while play is engaged. Always works for me. Another thing you can try if you want the machine to ignore the index on previously recorded material, is to switch the index function to "Counter"; When FF or REW, the unit will look for the counter "0000" rather than the index pulse. ...Accordianman
Aug 17, 2007 | JVC HR-S9500 S-VHS VCR
JVC HR-S3901 S-VHS / Switching from TV to VCR no longer works . . .
Ifyou do not see the VCR/TV button switch on the front panel, then its a problem most likly with the firmware in the microprocessor. If you do see the VCR/TV indicator switching in or on the front panel display, most likly a defective RF modulator/switcher or RF antenna pack. You may still be able to get one from like MCM or tritronics or PTS corp can rebuild it for you. I have seen this type of break down many times with VCR's as we used to do hundreds of VCR repairs a day as we did factory service for several companies in the NY/NJ area. Good Luck Please do not forget to rate this thread.
Dec 10, 2006 | JVC HR-S3901 S-VHS VCR
JVC HR-S9500U
OK, found the problem. Another website had the same question on the HR-S9600U, the 9500's replacement:
http://www.cippico.com/bbs/viewtopic.php?p=528&sid=ce3dfc944e4539181195720b836021f4
I checked my vcr, and, sure enough, there was a sort of clicking sound coming from the drum area immediately before the unit would go into "Auto" mode. I removed the complete drum assembly, and tore into the little gearbox, and found the two black, plastic gears with inside pinions that drive the metal screws to change the video head position had each cracked and were slipping on the shafts. This caused the gearbox to bind up.
Using a jeweler's screwdriver, I roughed up the metal shaft and the inside of the gears where they slip onto the shafts, and glued them on using a two-part epoxy. I then re-assembled it all, sorta setting the screws about two turns after their contact with the base of the upper drum. Now, upon power-up, the drum adjusting motor toggles one direction, then the other, and the unit stays on. Playback seems OK.
So, there you go. Yay me....
Oct 19, 2006 | JVC HR-S9500 S-VHS VCR
JVC HR-S9500 S-VHS VCR Logo
527 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
