Question about GE APN08AA Portable Air Conditioner
My air conditioner keeps blowing fuses in my apartment what do you do to stop this problem
  • 49 Answers
Could be loose terminal wiring.
Check Capacitors for swollen or leaking oil.
Use time delay fuses.
check amperage at fuse block.
Posted on Oct 13, 2010
3 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: 1996 volvo 960 air conditioner keeps blowing fuse.
your compressor-clutch coil is starting to short-out and drawing too much current,repl should alleviate your symptom
Posted on Jul 27, 2009
  • 44 Answers
SOURCE: My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Posted on Aug 21, 2009
Why won't the air conditioner blow air?
The very first thing you need to do is to check for fuses or say faulty fuse. Secondly check fan which starts along with air conditioner, it might be manually switched off or the fan may have been clogged. Also reason can be lack of refrigerant - charge your air conditioner with refrigerant. Last thing you need to check is cooling coil - the cooling coil may freeze if there is no refrigerant in the system.
Jun 11, 2013 | Ford Explorer Cars & Trucks
Fuses on AC unit keeps blowing need solution can't continue to b replacing fuses
are the fuses time delay if they are not then get them ..try cleaning the coil on the roof with a garden hose .if the coil is dirty the unit uses more amps to run causing fuses to blow /or you may need a new start capacitor for the compressor /fan its the round silver thing with wires connected to it .when you take it apart to clean ..good luck let me know../joe/
Aug 26, 2010 | Dometic Rooftop RV Air Conditioner
We took apart and washed pluged back in amd fuse keeps blowing
Take it back apart and make sure everything is dry. You can use a hair dryer to help.
Aug 01, 2010 | Heating & Cooling
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
Fuses blowing, wiring is good.how can I test the transformer?
disconnect the motor wiring. Should be a plug that you can locate and pull apart. now try applying power. Fuse may not blow. Also disconnect pump.
Oct 25, 2009 | Mastercool 67471 Evaporative Cooler Air...
The fuse bloww try replacing it but keep
Has this air conditoner been running on these fuses for awhile, and is it just now starting to blow the fuses? If so then have a short in the air conditioner. If this is the first time you're trying to run this unit on these fuses, then you need to check the rating plate on the air conditioner for the full or rated load amps and see if your fuses or the outlet rating will carry the amps the unit is drawing.
Aug 10, 2009 | Heating & Cooling
Air conditioner, fuel gauge, and temp gauge all stopped working at the same time
Three possibilities;
All related to blown fuses,
1- Fuse blown in the engine compartment LH.
2- Fuse blown in the cabin forward LH below the dashboard (below your legs left hand).
3- Fuse blown in the harness (wire bundles) below the dashboard very easy to reach with your hands “just look underneath steering wheel ".
U said " The air conditioner blows, but the air is not cold.
" Yes only the fan working which might receiving power independent all from those other mentioned things.
If all fuses OK. Then look for broken wires.
Regards;
MAR
Jun 03, 2009 | 2003 Saturn L-Series
GE APN08AA Portable Air Conditioner Logo
531 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
