Question about ASUS Computers & Internet
M4A79XTD EVO 790X/SB750 ATX CAN IT USE DDR2 MEMORY?
  • 111 Answers
No, the board will only use DDR3 1600/1333/1066
Posted on Jul 07, 2010
ASUS M4A79XTD EVO incomming sound <=> outgoing sound
Look at your mixer settings. sounds like too many things are on at the same time.
Apr 21, 2014 | ASUS M4A79XTD EVO AMD 790X Socket AM3 ATX...
I just built an asus m4a79xtd evo amd six core barebones kit but am wondering how to get the monitor working. there is a grafik card with dvi/vga and the monitor is plugged into the vga. but its not...
If you gat an istallation CD with the motherboard, it should load drivers for you, if not, hook up the way you want,and, restart. If you have Windows, it should try to load a generic dirver which might get you by. If that doen't work. Shut down the computer, intall the card and hook to that and restart, there is no on board video on that board:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131402
Once you install the card, you should get a picture, either from a generic driver or from the card itself, I don't beleive you will get graphics without the card installed and hooked up.
Jun 16, 2011 | ASUS M4A79XTD EVO Motherboard
New build with asus M4A79XTD EVO and AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor. When you hit the power button, the fans start but...
Hello
It almost sounds like a mistake at the pc start switch and reboot switch.
Check that you have your pc start wires from the front start button of the case, in the correct spot on the motherboard.
Also remove the memory sticks and reseat them.
The green light on the motherboard is good it means your getting power from the power supply.
The start and reboot switch wiring can be tricky if one plug is in the wrong spot on the motherboard.
Feb 03, 2011 | ASUS M4A79XTD EVO Motherboard
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
No post
maybe you have to enable the pci express monitor output for the grafikcard.I think your motherboard have a onboard grafik to.
Jun 02, 2010 | ASUS M4A79XTD EVO Motherboard
"Memory Turbo Card must be installed with either DDR2 or DDR3"!
It is not DDR2 or DDR3, it is new memory technology developed by Intel which is a flash memory module which reduces the time it takes for a computer to power up, access programs, and write data to the hard drive.
May 03, 2010 | MSI X48C Platinum - Socket 775 for Intel -...
Just finished building a pc using a M4A79XTD EVO motherboard. I turned on, all parts of the computer are running but no start up bios comes up
If its all working fine all that is the bios is set to display the Asus logo instead of the post. Theres a setting in bios to turn off if you prefer to see the post
Apr 18, 2010 | ASUS M4A79XTD EVO Motherboard
I havea GA-MA790X-UD4P AMD 790X; GbE; PhnII;DDR2 1333+; ATI FireX
It will support DDR2, of 1066 (backward compatible) and up to 16GB. If you put in two sticks, be sure they match in speed to get the best performance. It's also dual channel, so matching size will also be a good thing.
Mar 14, 2009 | Intel Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
