Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The ge Profile gas range allows knobs to turn and gas to emit without the pilot light igniting. I have found the knobs turn easily just by brushing up against them when reaching. This is very dangerous. Are there safety knobs available ex: ones you have to push in to turn?
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
SOURCE: stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Posted on Feb 08, 2008
th to replaceere is also an electronic ignitor in the back of the stove that sends the spark to the burners, if they light with a match , then I would check out the back for a little black box
Posted on Oct 24, 2008
MNTECH
  • 1543 Answers
SOURCE: GE gas range igniter continues to spark, won't shut off.
Often times, just leaving the range unplugged for a time will solve the problem, which is most often caused by water or a cleaning agent getting into an igniter switch behind a burner knob. After the switch drys out it usually starts working again. In the mean time, you can still use the burners by lighting them manually with one of those long lighters, but you will not be able to use the oven or broiler without electricity. If the range continues to spark after being left unplugged for more than a day or two, you will have to determine which switch behind the burner knobs is causing the problem. Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Posted on Feb 18, 2009
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
Where is the pilot light on a GE profile gas stove? The burners suddenly would not light except with igniter.
Please add the make and model number of the stove. Modern gas stoves and ranges do not have a pilot light. They light the gas with an electric spark. On these models, there is a knob setting for "Light" which triggers the spark. If there is no A/C voltage to the stove, you can use a match or butane lighter to light the stove with care.
I've found that the ignition system can fail if the burner caps are not seated properly. Debris in the burner area can also lead to the ignition spark problems. If you take off the burner cap and head (for some models), the electrode will be visible. Clean off any carbon build up on the electrodes for better sparks.
Jan 22, 2017 | GE Kitchen Ranges
How to light a pilot?
Any one of the knobs when pushed in will activate the igniters, if continually clicking it,s probably one of the knobs is not releasing. Check each one remove them (they just pull off) make sure they all are clean and nothing stuck under them.
regards Ray
Jul 23, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
I had problem with the GE Profile Spectra JGBP90 Gas Kitchen Range try to turn the stoe on , clicking noice but no flame. smell lots of gas. how can I light the pilot light back, where is it?
This range doesn't have a pilot,it has an electronic igniter. If you are smelling gas while trying to light, your igniter is bad and needs to be replaced. Remove the racks from the oven. Remove bottom panel in the oven. Remove the metal plate that covers the flame spreader. The igniter will now be visible. Try turning on the oven again. Take note of how bright the igniter gets. If it stays a orangish color it needs to be replaced. It needs to get to an almost bright white,
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have an XL44 and the burners work, but the oven won't turn on and I cannot find the pilot light. Where is the pilot light and do you have any other suggestions?
There is no pilot light. it uses a glowbar style igniter.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jan 13, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
No spark to ignite gas on cooktop
Shut off the stove. Then lift up the range top and you will see pilot lights. Remove the cover on the pilot lights. They could be blown out, but usually they are just dirty. Take a pin and poke it through the hole, then carefully scrub the tubes with a brush that go from the range to the pilot light. When your done with that....use a long match and light the pilot light, make sure no gas is on when you do this. No flames will come out, but it doesn't hurt to be extra careful.
This just happened to me so good timing!
Hope this helps
Sep 10, 2009 | GE Profile JGP636 Gas Cooktop
GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Jan 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top pilot light
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
