Question about Insignia NS-DCC5HB09 High Definition Flash Media Camcorder
Camera won,t turn on or take a charge
Charged the battery with a separate charger , cheked the voltage with a meter
    Novelist:
  • 170 Answers
If there is a firmware solution on Insignis-Products, you might be able to restore the camcorder to life that way.
However, if the unit won't turn on at all...even when a USB AC charger is used where it should function normally and completely...there is a problem with the camcorder and it may be bricked.
I hope this helps and I hope your camcorder isn't bricked.
Posted on Jul 20, 2010
Mark iii 5D will not turn on- battery is fully charged. I have tried taking the memory card out, battery out, lens off, etc and then replacing all of the above and restarting, but nothing happens.????...
And you are sure the fully charged battery also has enough capacity to power the camera? or it only reached a certain voltage so the charger says it is charged?
Also did check the contacts on the battery and in the camera?
Make sure the battery has enough power, by measuring the voltage with a multi meter. The voltage should be higher than what is printed on the battery.
Mar 15, 2015 | Cameras
Could i over charge my camera
Normally you don't over charge a battery, when it is charged for some extra hours. The electronics should stop the current. And when your computer is still working it should not have killed your camera. But be aware that as long as the camera is attached to a computer or a charger you can't switch it on.
Depending on how old your battery is and how it is used in the past, the battery could be gone. But it is not only to blame on the last charge cycle. Try measuring the voltage of the battery with a multi meter. The voltage should be a few tenths of a vat above the voltage printed in the battery.
I think your battery will be like 3,7 volt, and when charged the multi meter should read 4 volt. Anything below 3,7 volt means the battery is dead. (at least not fit for your camera)
It is better and safer to charge the battery on an external charger in the future.
Dec 29, 2013 | Kodak EasyShare M853 Digital Camera
Won't charge
The 4100 is a camera, not a battery charger. Connecting the camera to a computer's USB port is only going to drain the batteries faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).
If you're using an EN-MH1 rechargeable battery pack, you must charge it using a separate MH-71 battery charger. If you're using rechargeable AA batteries, you must charge them using an appropriate battery charger.
Sep 19, 2012 | Nikon Coolpix 4100 Digital Camera
Won't turn on
If a portable, could be no charge or bad battery---output voltage is marked on the charger and can be tested with a meter---if voltage and battery are good (most units will work with the charger hooked even if battery is bad) then the unit has either a damaged jack where charger connects or has a power supply problem inside it.
Apr 24, 2012 | Durabrand PDV-705 Portable DVD Player
My olympus vg-130 won't turn on or charge
Try this, it worked for me:-
Obtain a desktop style charger for the LI 70B battery and charge it separately from the camera. I got a charger at very low cost on eBay. I THINK that the original camera plus original charger won't cope with deeply discharged batteries. I also suggest making sure that the Auto-Power-Down is also switched ON in future. Good Luck.
Oct 21, 2011 | Cameras
I have a Olympus FE 4000. I purchased it this past year and it worked fine for a while but all of a sudden my camera shut down. I though the battery simply needed charging so i charged it. when i put it...
Yes, it's possible. Rechargeable batteries don't last forever. Lithium batteries in particular can fail early if they are allowed to become totally discharged.
The best way to proceed is to buy a new battery, then try to charge it. If it charges and the camera works, problem solved.
If it doesn't charge, then you will need a new charger. The battery will not be wasted though, as it is always handy to have a spare.
If having bought both new battery and new charger you camera still won't work, then you will have to look into your warranty or return it to the shop- however that works in your country.
It is possible to check the voltage of the battery with a meter (you can buy a general purpose multi-meter cheaply) but this takes a modicum of skill and interpretation. Even a run down battery may show some voltage on a meter, as it doesn't draw much current.
Nov 03, 2010 | Cameras
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 29, 2010 | Cameras
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Insignia NS-DCC5HB09 High Definition Flash Media Camcorder Logo
639 people viewed this question
Top Insignia Video Cameras Experts
Lawrence Oravetz
Are you an Insignia Video Camera Expert? Answer questions, earn points and help others
