Question about Ovens
Have put oven rack in backwards and now cant get it out
On my model #EW30EW65GS3 in the self cleaning cycle even tho I removed all the racks & the rack supports it keeps flashing remove racks
Hello. From what you're describing, there might be a problem with the rack switch. It is connected directly to the main oven display board at connector P10 for a single oven(See pic 3, left side, middle). On the double oven model, there will be a P12 connector near the same area. TURN OFF POWER TO THE OVEN BEFORE ATTEMPTING TO CHECK ANYTHING!! On the double oven display board, there will be a connector P10 and P12 for the upper and lower oven racks.The part number for the main oven display board is 7316516536 in case the switches are good. The rack switch part number for the upper and lower oven is 7318903403. The part number is the same for the switch in the single oven model. Note the designation on the exploded parts diagram as 14(with a circle around the part). I've included the last pic(the oven relay board) just for future information.The part number for it is 7316443919(dual oven relay board). If you are hesitant about attempting to troubleshoot the oven, definitely call for service! This can be an INVOLVED REPAIR requiring advanced troubleshooting. The connectors on the circuit board can be damaged easily as they are multi-pin devices. You will need a voltage/ohm meter with fine probe tips to perform continuity checks on the rack switch(s). I hope I helped you!
Sep 26, 2015 | Ovens
How do i take out an oven rack of a Kenmore stove thats been put in the wrong way i mean upside down!
lol.. I had the same problem a few years back, but my rack was totally jambed in there... I think if you raise the back of the rack and the front at the same time you can get it out.. with mine I had to keep jiggling it till it broke free.. good luck and have a great turkey day.
Nov 26, 2014 | Ovens
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
I have an Electrolux icon floor model. I set it to clean after pulling the racks, the lock light came on but nothing happened. I left it for about 15 mins and still nothing. I turned off the clean cycle...
On the E30EW85ESP3 model I had to pull the racks "and" the supports mounted on the side walls. Otherwise it would not allow the clean cycle to begin. Hope this helps.
Dec 20, 2012 | Electrolux ICON Designer E30SO75ESS Oven
I removed all the racks from my upper oven (including the side racks) to self-clean and am getting the "remove racks" light. I've cleaned the oven before and never had this happen. The...
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Aug 21, 2011 | Electrolux ICON Designer E30SO75ESS Oven
I took my shelves out to clean my oven and cant get them back in
Hello, as you are looking at the rack the two triangular shapes face down the scooped part at the rear facing up. pick up the rack put your hands on the little triangles facing down put the scooped end in on a downward angle about (30 degrees) slide end in first and straighten out. good luck
Dec 22, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Nov 01, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
291 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
