Question about Sharp AF-S100FX Comfort Touch Air Conditioner
Air conditioner will only run a short time then shut off.
Keeps shutting off. Have a E-1 error. An Air Conditioner
  • 31 Answers
Manula or online site will tell you what e-1 is, I would think it is a power outtage reading and unit needs to be reset. Dont be afraid to call your units manufacturer and ask tech how to reset unit with an E1 error.
Posted on Jul 07, 2010
Troubleshooting
If by "not shut off" you mean the blower keeps running, that is normal operation. The blower only shuts off when the system is turned off.
When in cool or heat mode the room temperature is sensed in the units return air which requires air movement by the blower.
Dec 11, 2013 | Mitsubishi MSH17TN Air Conditioner
Hi. I have a Goodman air conditioner model #ck36-1b. When I turn it on the condenser turns on for about 1 minute then shuts off. The fan on it continues to run and the condenser will turn on every once and...
If the entire condenser is shutting down, it is cutting off and on by a pressure switch. Either the outdoor coil is stopped up or it is low on refrigerant.
If the compressor alone is shutting off and the fan on top keeps running you may have a run capacitor shorted. Pull the fuses, look into the electrical compartment and find what looks like a big battery. This is the capacitor. If it is "pregnant" or swollen it is shorted.
May 13, 2011 | Goodman CLQ36AR49 Air Conditioner
Air conditioner frezing up.clean filter and air conditioner but still ferzing up
If its doing it over night or in several hours, you need to check the thermostat. Turn it all the way to the warmest setting and listen for the compressor to shut off. If the compressor keeps running at the warmest position your thermostat is shorted. If you do hear your compressor shut off , and the thermostat is working, you are probably low on refrigerant.
Apr 14, 2011 | Kenmore Single Room Air Conditioner
The unit runs for a short time then shuts off.
Usually when that happens the unit is low on charge...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 26, 2010 | Heating & Cooling
Air conditioner shuts off and trips breaker on power cord
It sounds like a short or ground in the compressor. If you have an ohmmeter, unplug the unit and use the meter to check the wires to the compressor. Connect 1 meter lead to the compressor case then to the wires coming from the compressor 1 at a time. If none are grounded then connect 1 meter lead to the Com. Then connect the other lead first to the run wire, then to the start wire reading the resistance each time. neither should be less than 1. You can also check the condenser fan.
May 25, 2010 | Whirlpool ACP102PS Portable Air...
This goldstar air conditioner model is WG2405RY7 It has an energy saver, but the unit just keeps running and won't shut off, everything else works.
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Jun 29, 2009 | Goldstar M1003R Air Conditioner
Shutting off
I would try the same solution as the E1 error code, Not sure if it will work, but it seems to be the same issue
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Sep 10, 2008 | Sharp AF-S120FX Air Conditioner
Window air conditioner keeps kicking off.
is the fans running at all. you have a short some where. od you know how to use an ohm meter? let me know
May 10, 2007 | LG LB1200ER Air Conditioner
Sharp AF-S100FX Comfort Touch Air Conditioner Logo
594 people viewed this question
Top Sharp Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
